Bit of DIY for a change
Discussion in 'Maintenance' started by Kevin1, Apr 14, 2015.
  1. Kevin1
    Kevin1 Elite Member
    I actually took my own back wheel out today to clean the chain and back wheel. First time I've done this in about 30 years.
    [​IMG]Untitled by rushforthk, on Flickr
  2. Mike07
    Mike07 Active Member
    Was it heavier or lighter than it used to be?
    Mike.
  3. 1000rr73
    1000rr73 Active Member
    And it looks like you decided to do it down the end of a country lane too you madman!
  4. exuptoy
    exuptoy Elite Member
    Just did the same to mine this afternoon, and the front. Fitted a set of captive spacers to both wheels at the same time. Good things them. At least it's easier than needing 3 pair of hands when changing your wheels.
  5. Kevin1
    Kevin1 Elite Member
    Mike - probably about the same, but like Exup' says and additional hand would be useful. I couldn't do both wheels on the same day! That is just plain madness.
  6. exuptoy
    Both the wheels took me less than an hour and a half. Those captive spacers make a big difference. I need to get one of those stub shafts sorted next.
