Solid light - Engine Management
Discussion in 'Maintenance' started by Mr OCD, Aug 7, 2017.
  1. Mr OCD
    Mr OCD Well-Known Member
    Currently stripping the bike down in preparation for trade-in...
    Of course the engine management light is solid.
    Clearly I've missed something. Any ideas?
  2. Mr OCD
    Figured it out.
    Side stand needs to be down to get the code. :)
  3. Mr OCD
    Anyone know what code that's flashing?
    Can't make it out!
  4. tuktuk
    tuktuk Elite Member
    What was the diagnosis from the garage you had it at?
    Seen a post about the crank in your other thread?
  5. Mr OCD
    Long story.
    I just need to know the fault code :)
  6. Slick
    counted 14 long blinks or maybe 13-1
    Could be one of the injector connectors are loose, did you remove a PCV?
  7. Mr OCD
    Yes I did ... thanks will check them. :)
  8. Mr OCD
    All connectors checked in the area where injectors are ... still a flashing light. :(
  9. Mr OCD
    13-1, 14-1 refer to injector connections. Which will result in non-start ... it runs fine. I've had the tank up anyway and unplugged and plugged everything back in though.
