Highway Code signs test
Discussion in 'Lounge' started by T.C, Oct 30, 2017.
  1. T.C
    T.C Elite Member
  2. Kevin1
    Kevin1 Elite Member
    9/10. No vehicles sign got me
  3. SimonRR
    SimonRR God Like
    10/10 for me :D
  4. ledwardio
    ledwardio Active Member
    10/10 None of the answers for the last question were factually right, but I knew what the Nannies were after.
  5. Kevin1
    Kevin1 Elite Member
    I don’t think we all get the same questions or in the same order.
  6. ledwardio
    Aha! It was this one:
    Options were:
    Keep your speed the same
    Slow down
    Speed up
    The highway code description is 'Bend to right (or left if symbol reversed)'
  7. Kevin1
    Kevin1 Elite Member
    I find it a bit strange that they don’t stick to the Highway Code explanation
  8. Lozzy
    Ah but lads.....
    The symbol is in a red triangle which means it's a 'Warning' sign.....
    so...Warning Bend to Right.....Slow Down
    Ah well, back to the ironing.......:p
    :D
  9. SimonRR
    SimonRR God Like
    what!!! you slow down for bends lozy? speed up and hang off and get your knee down...:D:D;) thought the red triangle meant "Fun Ahead"...;)
  10. ledwardio
    :D[/QUOTE]
    No, I think the Fun Ahead one is this one:
  11. T.C
    T.C Elite Member
    But the question was "What should you do?" It did not ask what does it mean, so the generic answer of slow down is correct
  12. ledwardio
    Well, the opening page of the quiz says 'But are you 100% sure of what every road sign is telling you to do?'
    That sign is telling you to prepare for a turn in the road. You may need to slow down, you may not, the sign cannot advise :)
  13. Lozzy
    Think this lad got 9/10 in the quiz as well :D
  14. T.C
    T.C Elite Member
    Then why are they called Advisory signs if they cannot advise? :eek:
    It is advising you of a bend to the right ahead, you may be required to slow down.
    Triangular signs red border white backgrounds = advisory Round signs red border white background = order or prohibition
  15. ledwardio
    Because they are not called advisory signs, they are called warning signs - this one is warning of an upcoming bend.
    Here you go, knock yourself out:
    https://www.gov.uk/guidance/the-highway-code/traffic-signs
  16. T.C
    T.C Elite Member
    OK.
    I am old school so I will stick with Advisory which is what they used to be called or advanced warning which seems to be the common term.
    I am not going to get het up over it.
  17. ledwardio
    They do have a habit of changing things ;)
