1. bazzashadow
    bazzashadow Elite Member
    don`t be dirty:p
    cable luber has anyone used one and are they any good
    and what lube do you use( can`t believe I asked that;))
  2. Nigelg79
    Nigelg79 Active Member
    Yep I use one similar to the Oxford tool, works a treat for clutch and choke cables. Use a proper cable lube or something with PTFE which coats the cable. WD-40 is no good for this job.
    Basically keep spraying until you see it coming out the other end of the cable!
  3. bazzashadow
    37BF9DFA-64A6-4C75-BACA-EDA31651A150.png Was thinking of this
  4. Spygoat
    Spygoat Well-Known Member
    Dual screw for tighter seal...mmmhmmm
  5. bazzashadow
    What is the mmmhmmm
    Don’t trust what they are saying?
    Had a bad experience?
    Halfords advertise the same thing “duel screw” but there picture only shows a single screw
    Or is this getting dirty:oops:
    It’s early in the morning :confused:
  6. Spygoat
    For the sake of actual technical advise, a "dual screw" is the same type I use. As mentioned, use a PTFE lubricant to avoid actually making the cables worse and simply pump it in until you see it dribble out the other end of the cable.
    Now for the mmmhmmm...dual screw, lube, pump, dribble...I'm basically 10 between the ears so it's difficult not to comment.
  7. Nigelg79
