  1. hitch
    hitch Elite Member
    Don’t know what the manual says about measuring/adjusting chain for the blade?
    I know my GSXR manual states to measure and adjust on the side stand.
  2. blink
    blink Well-Known Member
    I shall read the manual then lol
    Still easier to oil it on a stand tho
  3. nigelrb
    Yep, side stand also for the Blade - courtesy page 153 2017 - 18 Owner's Manual. (25 - 35 mm slack)
  4. hitch
    hitch Elite Member
    Definitely, ...and so begins the best stand debate ;)
  5. blink
    And you can adjust it on the stand?
  6. blink
    A not expensive one
  7. roboticus
    roboticus Active Member
    there u go make some
    • Funny Funny x 4
  8. Alen
    Alen Member
    I have dismantled oem fairings, instaled 19 front brake pump, and now waiting for racing parts to come....
  9. F1CT1C10U5
    F1CT1C10U5 Well-Known Member
    How long did it take you to take apart all the fairings and headlights? Just trying to compare to the 08-11 version.
  10. Alen
    Alen Member
    Two hours.
  11. F1CT1C10U5
    It takes me around 3 to 4 hours to do mine... Maybe i'm just not as handy as you... lol
  12. Alen
    Alen Member
    Sometimes goes faster sometimes slower...I've done it a lot of times so for me it is maybe easier.
  13. F1CT1C10U5
    yeah, maybe. I've done it to mine 3 or 4 times over the years... I always fear breaking something, which I did last time, breaking a tab on the right side fairing... had to buy a new one, since the right fairing would not lock to the belly pan... :(
  14. nigelrb
    That's some serious preparation you're doing there. I look forward to following your project.
    It would be wise, and benefit other members, if you started a specific thread for it, such as 2015 (or whatever) Track Preparation.
    Agree. My fear also. There is a real art in fitting the belly pan (not that I've mastered it:rolleyes:) because we have to be slightly heavy-handed to squeeze in the final 2 tabs. I have some very strong glues and bonds, but I am sure that none is strong enough to support the pressure and vibration on those tabs. @PauloHRC did offer a good remedy though; drill through and fit one of the black 'push pins'. I am sure it would actually make it more secure and also simpler to ultimately remove.
  15. F1CT1C10U5
    I now have a better understanding in how to do it safely... too bad it took a broken tab for me to learn
    Yup, I had that done in mine... Altought it was still quite hard to fix everything together the way I did it, but after it was done, it would STAY fixed:
    Now, with the new fairing, I don't use that "feature", but still have the holes in the belly pan, so I can go back to that solution if needed.
  16. nigelrb
    Whooaaa:). I'm looking at that SUPER BLING (sorry @Lozzy:p) carbon tank inserts and under seat fillers (formerly plastic).
    I just HAVE to have them. Currently doing some serious Googling. Are yours from Spain/Portugal or Europe?
  17. F1CT1C10U5
    What do you mean? Portugal and Spain are in Europe! :p
    I bought them off eBay. The fitting isn't perfect. Looking from a low angle, you can see the insert tabs in the middle... :(
    It's fixable, but it's good enough for me in the current state.
    The under seat fillers... are just the stock ones wrapped in good looking vinyl
  18. nigelrb
    Yep, fair enough. I was thinking from a postage point of view as in close proximity as opposed to Germany etc.
    I've seen a few on ebay; some from China and some nearly double the price from UK (though not necessarily made here!) I can compromise on fit, but thanks for the tip off!;)
  19. Alen
    Alen Member
    Yes, I will do that :).
  20. Demmel
    Demmel Member
    Nigel, if you buy them and they will be installed perfectly - let me know what and from whom you bought!
    I also looked at them for a long time - but I want to have a perfect fit.
