Battery recommendations
Discussion in 'Maintenance' started by Lee Beddows, Mar 2, 2019.
  1. Lee Beddows
    Lee Beddows New Member
    Is it AA or AAA? :D
    I've got a datatool 2 fitted to the blade and it's draining the battery quickly so think I may need a new one soon.
    Do I go bigger Ah and what makes does everyone recommend
    Tia
    Lee
  2. sps170373
    Get rid of the datatool! Unless you absolutely need it
    Might be worth going lithium route as most offer more cranking amps that lead acid batteries
  3. Boothman
  4. Blade runner 1
    Blade runner 1 Elite Member
    Avoid Motobatt, I’ve had 2 of them leak.
  5. bonjo
    if you have constant drain on your battery, then lithium is the wrong direction to take as their ah is less than 1/2 of your AGM battery.
    I think shorai sells one which comes close to the AGM ah rating.
    Batteries suffer from capacity fade as they age. You may find getting another new AGM will solve your problem. Unless you have the space, going bigger on AGM means bigger size & heavier article.
    I assume there are no hidden issues with either your data tool or the bike's parasitic drain
  6. Demmel
    Demmel Member
    I use MotoBatt MBTZ7S two years. No broblem.
  7. nigelrb
    Never a truer word. My Pacemaker's nearly croaked it.:D
  8. bonjo
    had an unlce who had one fitted. his doc said even if he kicks the bucket, his heart will carry on beating!
  9. bazzashadow
    bazzashadow Elite Member
    gutted if this is true
    I done a lot of reading and I have just brought a motobatt
    now you have me worried:(
  10. Robbo52
    Robbo52 Active Member
    I’ve got a motobatt, been on for 12 months and zero issues. Changed oil last week, started it up after 4 months of standing and it fired on the first press. Thumbs up from me.
  11. nigelrb
    Difference is that @Blade runner 1 was doing wheelies at up to 80 degrees angle!:)
  12. sps170373
    Not sure where you got your info from but most lithium have more ah per hour and cold cranking amps
  13. bazzashadow
  14. Blade runner 1
    Regarding the Mottobat I bought 2 at the same time, one for me and one for my brother. My battery leaked after about a month and my brother’s leaked a couple of months later, both from the seal at the top. I ground a little channel round the seal with a dremel and filled it with epoxy glue, been fine ever since. Maybe a bad batch, but it would put me off buying another. The real problem is if drips onto the swing arm and is left unchecked it could easily damage the surface. It’s still going strong though after 2 years.
  15. bonjo
    Shorei actually list 2 batteries a higher capacity one (£200?) which i in your pic.
    a good few don't even specify the ah (because it is too low) arguing that it is not relevant because this is a lead battery spec. However if you have current draw when your bike is off, then the ah become important. Checl out skyrich, shido (2.4ah), jml etc
    CCA is actually specified at 0F (-18C you can find the proper testing info on line) and again the lithium makers specify theirs at room temperature (think somewhere between 15~20C) as their product will not operate at those temps. Although alian do mention cold temp performance.
    So on both counts the makers provide numbers and marketting claims which is not correct (honest?). To me, lithium battery is a great substitute provided you are aware of its pitfalls and how it suits the your bike's use:)
  16. raphael
    I’ve just got a lithium and to be honest I’m not to impressed with it as all he numbers are better than the original acid battery but it doesn’t seem as strong on the starter button
  17. nigelrb
    Interesting deduction @raphael . I am sure you wouldn't buy a crap product so the difference must have been quite noticeable.
    As a point of interest, I ran my SP (std lithium batt) last week for the first time since October. The batt is on permanent tender. The bike started instantly as if it hadn't been laid up at all. I was actually surprised. I don't notice any diff in starting between my 2011 (ordinary batt) and 2018. This does make me wonder whether your new battery was fully charged when you installed it - though I do believe you would be right on top of that.
  18. SimonRR
    SimonRR God Like
    Had 3 Motobatt's and never had a problem, not ride for a while and never charged always starts first time, if you don't want the fire worry of a lithium get a AGM battery they are great
  19. Slick
    Same as my experience, if you're a hard core commuter lithium may not be the best option. They suffer badly in cold weather. Anyone that uses LI for other things such as RC models, air soft, drone etc will know they are super fussy on charge and storage voltage. TBH the stator and RR cant provide the amps/voltage to ensure battery longevity.
    Tried all the cheaper AGMs too no name ebay special motto batt etc but keep on going back to Yuasa
  20. raphael
    cheers Jon, glad it wasn’t just me, it’s a shame I will have to go back to the normal battery as the space the lithium creates is handy.
    #20 raphael, Mar 10, 2019
