Front pads and some bling
Discussion in 'Maintenance' started by Gravel trap, Apr 6, 2019.
  1. Gravel trap
    Gravel trap Elite Member
    Time to change the front pads again and replace pad pins and mounts for something far easier on the eye. 20190406_123841.jpg
  2. Gravel trap
    I applied some acf 50 to the bolts and pins on Friday night and left to dry . Removed calipers and cleaned in parts washer then fitted new pads after scamfering edges slightly bolted and tourqed up and job done. Front end looks a lot better now I think . Old pins a right state but that's two winters worth of committing I suppose. 20190406_123726.jpg
  3. Gravel trap
  4. Gravel trap
  5. mk3golfcab
    mk3golfcab Elite Member
  6. hitch
    hitch Elite Member
    How much were the bolts, out of interest?
    I bought caliper bolts for £20 from RaceTi
  7. nigelrb
    My sentiments too. I don't care whether it stops or not; so long as it's nice and clean!!:D
    • Agree Agree x 3
  8. nigelrb
    Aisle 12 in Tesco:D:D.
    • Funny Funny x 3
  9. Gravel trap
    Pins were seventeen quid and bolts twenty. Next day delivery too. I've always used gen or pro bolt before but I'm converted to race bolt now . Good enough for the lcr team its good enough for me to use as I shout at prick on phones during my commute.
  10. Great Guy
    Great Guy Well-Known Member
    I am going to do similar. However; my pinch bolts and caliper bolts will be in gold.
  11. Gravel trap
    Isn't gold a bit tricky to torque
  12. nigelrb
    No, because @Great Guy has a gold torque wrench.:rolleyes:;)
  13. Great Guy
    They call me "Bling Blade Guy."
    • Funny Funny x 3
  14. bonjo
    That is one job I will have to do at some point. Looks good.
    are the pins & bolts titanium or S-steel?
    Could you post the part numbers as I thought the bolts were £12 each (similar range to the OEM ones)
  15. raphael
    While your at it mate put some stainless pistons in them as by the look of those old pins I wouldn’t be surprised if the standard one aren’t pitted?
  16. Gravel trap
    I'll check workshop bin for bags with the numbers on. Pistons ok really slight pitting on surface edge but otherwise ok. I am planning on putting a set in next pad change. Need to do cam timing first so a shim kit to buy next.
