Newbie with troublesome blade
Discussion in 'New Members' started by bladeguy69, Jun 6, 2019.
  1. Bikeboy
    Bikeboy Active Member
    Everyone assumes that if something is new it's ok. ie. a battery. Its not always the case. I had to change a coil 3times last week to find one that worked. All brand new and sealed in a bag in a box.
  2. Lozzy
    Yes mine was a brand new battery straight out of box...and almost identical issue as the poster.
  3. nigelrb
    A wonderful analogy of my marital situations . . . :(;)
    • Funny Funny x 3
  4. bazzashadow
    bazzashadow Elite Member
  5. Kevin1
    Kevin1 Elite Member
    Hi
    I was wondering. Did you have the free tracker installed. It's a battery killer.
  6. Kevin1
    Kevin1 Elite Member
    Although it shouldn't kill a newly replaced battery as quick as that.
  7. Barstewardsquad
    This doesn't sound like a battery drain issue. If it was an alarm/tracker etc. then I would expect problems when first starting the bike and OP is saying it is starting ok initially.
  8. Kevin1
    Kevin1 Elite Member
  9. Lozzy
    Was it completely dead or could you bump it? Just asking because the new 'faulty' battery I had in would start fine and I could ride 4 miles...stop at a shop and in the few minutes I was there it wouldn't then start but I was able to bump it the few times it happened. Popped another new battery in and it was sorted.
  10. Selmer50mark
    Hello and welcome ,I've probably seen you at the bridge
  11. BlackDevil
    Hi and welcome !
  12. Black & White
    Hi bladeguy69. Did you get it sorted? I've got electrical & testing knowledge. Do you have a multi-meter?
