Wheel position
Discussion in 'Maintenance' started by Mark emery, Aug 7, 2019.
  1. Mark emery
    Mark emery New Member
    so I’m going to fit a new chain and I’m wondering what is the ideal position of the wheel ie swing arm pivot to spindle? Before I go ahead and rivet it. Cheers in advance
  2. nigelrb
    Leave enough for adjusting stretched chain.;)
  3. Spygoat
    Spygoat Well-Known Member
    This. I just go with the recommended links (I believe it is 116 on my 2016 SP).
  4. CharlieR85
    Knowing you are a keen wordsmith I'm going to help you move your skills towards God-like status Nigel..... Chains become worn, they don't stretch. ;););)
  5. nigelrb
    Fair call, Charles. But I'd sure like to see an analyst's report of a worn chain versus and brand newy, and I think, based on the performance of metals under duress, that the result would show elongation of most links (if not all) with the resultant length of the chain being greater than the original spec.
    This is just my educated opinion after serving an apprenticeship as a Fitter and Turner and a lengthy period as a motorcycle mechanic. I'm heading to Google - stay tuned!!:);)
  6. CharlieR85
    I can PM you my credentials if required. ;)
  7. nigelrb
