New to forum please help
Discussion in 'New Members' started by Vas, May 1, 2020.
  1. Vas
    Vas Active Member
    hey guys I have a problem with my 2009 fire blade when it’s to about 100 degrees the drop a couple of times on tick over then cuts out with no engine management faults but will re start straight away, I have by passed neutral switch and side stand switch which never helped, any help appreciated
  2. Bikeboy
    Bikeboy Active Member
    Is it related to the fab cutting in ?
  3. Boothman
    Hi and welcome to the forum
  4. Vas
    Vas Active Member
    No relation to the fan it runs ok ideling until it gets gets hot and then the revs drops a couple of times then cuts out. I noticed that the fuel tank is a lot hotter than previous bikes
  5. bonjo
    welcome to the club
    does this happen on the move only?
    I have never noticed the fuel tank running hot or not even warm. The tank has a venting system which ends with a short elbow tube on th right. Could be there is pressure building up and starving the engine (like vapor lock). worth checking
  6. Vas
    Vas Active Member
    Checked that today all seems ok even run it with the filler cap open but makes no difference, on tick over it still cuts out when the engine gets warm but restarts as so as I press the start button also bypass the kill switch today but made no difference.
  7. Vas
    Vas Active Member
    It only cuts out on tick over when I pull up to a set off lights or stop at a junction or have it ticking over in the drive way some times out on the road it has a little miss fire and runs rough put clear
  8. PauloHRC
    Hi and welcome, hope you've sorted the problem!
  9. Vas
    Vas Active Member
    Hi mate yes I’ve got to the bottom of it now after checking everything I could and running a fuel pump pressure test and finding no faults with anything I decided to take a gamble and replace the cam shaft position sensor and bingo it has never cut out since fitting the new sensor. Thanks for you’re help guys
  10. PauloHRC
    Great result mate!
  11. mk3golfcab
    mk3golfcab Elite Member
    Hi and welcome, glad you got your issue sorted :)
  12. Stuish
    Stuish Senior Member
    Missed this, welcome to the forum! Good news on the fix too :D
  13. Blade runner 1
    Blade runner 1 Elite Member
    Hello welcome
  14. BlackDevil
    Hi and welcome !
