Noisy front end
Discussion in 'General 1000RR Discussion' started by Allan Priestley, Jun 11, 2020.
  1. Allan Priestley
    Allan Priestley Active Member
    Hi guys
    I've bought a 2013 Blade and have noticed that at lowish speeds over moderate bumps I am getting a clunking noise from the front end . It happens as I approach my driveway over a small 2 inch kerb .
    The guy i bought the bike from said that a honda dealer serviced forks and seals at bikes last service . But the forks are nowhere near compressing anyway so i dont think it's that. I've checked all bolts at wheel and forks etc . Bike has 10k miles, any ideas ,, TI A.
    I have read online that so.e blade owners report similar and are putting it down to the fork set up on the bike and not to worry .
  2. dave the rave
    dave the rave Active Member
    It will be the headstock bearings!.sit on the bike press the front brake and push on the forks to make them compress and bounce back up see if you can hear the knock do it loads of times.If it clunks happy days you know what it is on to youtube find a solution
  3. Slick
    I recall many noticing the BPF on the 2012+ having a clunky sound will have a bit of search
  4. Allan Priestley
    Thanks very much Slick
  5. Slick
  6. Allan Priestley
  7. Allan Priestley
    Hi slick. Thanks for the thread hunt , alot of the posts on the thread talk about brake judder etc under braking which isnt relevant however a few mention the symptoms I'm experiencing which his more often a knocking over bumps .
    Showa forks seem to be the culprit . Can live with the noise as long as it safe ?
  8. vic_ster51
    vic_ster51 Active Member
    It a common noise on the BPF, say when going very slow or moving bike over bumps. Honda dealer even said about it aswell. Esp over kerbs etc on paths. All mine done it
  9. Allan Priestley
    Thanks for your replies, makes it a lot more tolerable
  10. Allan Priestley
    Update on clunking noise, bike was taken to honda dealer on Monday , after a test ride and examination the diagnosis was the bushes at the bottom of the fork legs were shot .
    Parts ordered , and seals etc replaced all under warranty and the bike is now as quiet as it should be over bumps
  11. 1000rr73
    1000rr73 Active Member
    Strange one. I’ve had 3 post 2012 blades, two of them from new and they’ve all done the clunking thing. Tried the warranty and dealer route to start but always told it was fine
  12. Jez
    I have a 2013 with no clunking, For Honda/Dealers to say some of the forks sound like that I would say is a Honda cop out. If it clunks something is not right, It may be safe but still not right.
