As above wanting a front oem screen to fit my 2015 fireblade, think its a double bubble but not sure if they come as standard like that! Must be mint though and not wanting to spend much more than £20ish!!!
I'll see if I can find it. Garage or loft? From what I remember it hasn't been used. I had it replaced when the bike was new. I try and find it
Found it. This one isn’t a double bubble like the one above and it must’ve been on the bike at some point. It has the inevitable wash marks
has this 1 not got honda racing on the side? as the 1 with hole on the front is the official honda racing high screen usually i thought.
It may well have, but it is not the standard screen, it is the high level one or Honda Racing screen. The 2012 standard screen does not have the hole at the base, not the little bit of black plastic. It looks more like the one further up, but did not have the double bubble bit, which started with the 2014 bikes.
I am sure you are right. But the holes are the same as @Glenandemm wanted. I've only ever a 2012 and a 2018 blade. It can only have come off the 2012. It is also a genuine Honda screen. It's a mystery
