Wanted front screen to fit 2015
Discussion in 'Wanted' started by Glenandemm, Jan 24, 2021.
  1. Glenandemm
    Glenandemm Active Member
    As above wanting a front oem screen to fit my 2015 fireblade, think its a double bubble but not sure if they come as standard like that!
    Must be mint though and not wanting to spend much more than £20ish!!!
    #1 Glenandemm, Jan 24, 2021
  2. Kevin1
    Kevin1 Elite Member
    I have a standard OEM screen to fit a 2012. I think they are the same.
  3. Glenandemm
    What’s the condition like pal and any pics?
  4. Kevin1
    Kevin1 Elite Member
    I'll see if I can find it. Garage or loft? From what I remember it hasn't been used. I had it replaced when the bike was new. I try and find it
  5. CharlieR85
    CharlieR85 Elite Member
    Not fancy an MRA or zero gravity double bubble?
  6. Glenandemm
    No not really pal just want the standard Honda screen like this
  7. Kevin1
    Kevin1 Elite Member
    Found it. This one isn’t a double bubble like the one above and it must’ve been on the bike at some point. It has the inevitable wash marks 877062EC-2A99-4691-AFE0-A17A32D818AA.jpeg
  8. Glenandemm
    agh cheers bud but I’m really after the double bubble Honda screen.
    Thanks for trying anyway
  9. vic_ster51
    vic_ster51 Active Member
    has this 1 not got honda racing on the side? as the 1 with hole on the front is the official honda racing high screen usually i thought.
  10. Kevin1
    Kevin1 Elite Member
    That’s the screen that came off my 2012. 20th anniversary model.
  11. Iain
    Iain Active Member
    It may well have, but it is not the standard screen, it is the high level one or Honda Racing screen.
    The 2012 standard screen does not have the hole at the base, not the little bit of black plastic. It looks more like the one further up, but did not have the double bubble bit, which started with the 2014 bikes.
  12. Kevin1
    Kevin1 Elite Member
    I am sure you are right. But the holes are the same as @Glenandemm wanted. I've only ever a 2012 and a 2018 blade. It can only have come off the 2012. It is also a genuine Honda screen. It's a mystery :)
