Form Weymouth .uk
Discussion in 'New Members' started by Martyn1000rr, Nov 10, 2021.
  1. Martyn1000rr
    Martyn1000rr New Member
    Hi from Weymouth uk. Just joined the forum
    In the middle of rebuilding my transmission on the 1000rr rr5
  2. Boothman
    Hi and welcome to the forum
  3. Barstewardsquad
    Welcome!
  4. Kevin1
    Kevin1 Elite Member
    Hi
    Interesting project. We love pics
  5. Selmer50mark
    Hello and welcome
    • Dislike Dislike x 1
  6. kirk holmes
    kirk holmes Member
    Welcome, welcome
  7. Martyn1000rr
    After Having the bike for over a year it developed a noise thinking it was cam chain had that replaced with new tensioner as well that didn’t solve the noise it was coming from the right hand side clutch side of the engine after going out one evening she started playing up and felt like slipping teeth or gears inside which made me take and strip the bike down and finding the problem…… free bolts holding a plate that holds the bearings in to the final drive shaft was not in place and found them in the oil pan.. Which give the shaft a little bit of play with the bearing And causing the transmission plate Casing to shatter in half causing gears grinding ………
  8. Kevin1
    Kevin1 Elite Member
    Was it like that when you bought it?
    I wonder what caused the initial problem
  9. bradt
    bradt Elite Member
    Hi and welcome.
  10. Blade runner 1
    Blade runner 1 Elite Member
    Hello and welcome
  11. Martyn1000rr
    When test on a test ride I hit a false neutral in fourth gear a few times mentioned it to the shop and they said it might have been just me where I haven’t ridden in a long time so I took it on the chin and purchased the bike developed a little bit of a rattle I’ve sent it back to the shop on the warranty and they replaced the chain tension guide but there is still a slight rattle/knocking then over the few months I’ve not riding it very much it got a hell of a lot worse and on a journey back from around 50 miles away whilst riding it accelerating the clutch would pull itself in something that I’ve never experienced on a bike before and don’t know why or how that is possible so decided to tear it down And found the internal problem
  12. Coda
    Coda Active Member
    Do you not have full stops or commas on your keyboard? Here, have a few of mine. ….,,,, No charge.
    • Downvote Downvote x 1
  13. Kevin1
    Kevin1 Elite Member
    I'm guessing you aren't new to stripping gearboxes down. You must have a well thumbed Haynes manual by now, with oily pages. :)
  14. Lozzy
    Ooooo :confused: shades of Nigel :eek: stop it.....you'll traumatise us all lol
    • Funny Funny x 3
    • Optimistic Optimistic x 1
  15. raphael
    check you out
  16. Martyn1000rr
    It’s the first one I’ve ever done but it was fairly straightforward and bought a brand-new haynes manual LOL
  17. Martyn1000rr
    Init what a melt lol
  18. BlackDevil
    Hi and welcome !
