Oxford Lever Guard
Discussion in 'Mods, Upgrades, Accessories and Products' started by Edy, May 1, 2022.
  1. Edy
    Edy Member
    Hi Guys
    I have attempted, unsuccessfully, to fit a lever guard to my blade for an upcoming track day. By the looks of it I need to remove the throttle assembly to change the inserts for the lever guard. I am not too confident in doing this. Can anyone point me in the direction of a lever guard that will bolt straight onto my bar without any internal modification. 2018 model. Thanks.
  2. CharlieR85
  3. Edy
    Edy Member
  4. CharlieR85
    This is what I mean by get it moving/lever it out with screwdrivers. Once it's wiggling use the M6 bolt with something heavy that will slide over it as a slide hammer.
  5. Edy
    Edy Member
    Thanks very much for the help, i will get back on it tomorrow morning. I’ll let you know how it goes.
  6. CharlieR85
    You'll get it mate, don't give up.
  7. NS400R
    NS400R Elite Member
    I left the insert in my 2017. Added a little silicone sealant and used an R&G guard. One track done, I swap back to the std bar end
  8. CharlieR85
    Did you sort it @Edy ?
  9. Edy
    Edy Member
    Yes Charlie, thanks for your help. I didn’t get round to it until yesterday. Molegrips, light tap with a hammer did the job. I didn’t use a separate screw and ended up bending the original bar end screw. Not the end of the world, I will buy a new one. Bloody pain though. Good to go for the track day at Donnington on Wednesday.
