Suspension setup and/or new rubber
Discussion in 'General 1000RR Discussion' started by midders, Oct 15, 2023.
  1. midders
    midders New Member
    Hi there
    I just bought a 2007 CBR1000RR about 20 years after having a '96 900RR and it's insanely fast, but after a few test rides, it's not handling as well as I'd like.
    I think the last owner had it setup for track days because the suspension is very stiff (Ohlins). The rubber is Metzeler Roadtec 01 SE.
    Can anyone point me in the right direction for making it a better road bike? Should I just adjust the shocks, or replace with factory? Bridgestone BT56s transformed the handling of my last blade, and the Battleax S22s look tasty...?
    Slàinte
    midders
  2. PauloHRC
    Maybe look at changing the fork springs and or fork oil. I wouldn't swap them out completely though.
    Roadtec tyres are perfect for what you want, just check the pressures, tread and age. Low pressure, uneven wear and old hard tyres will all affect handling.
  3. Barstewardsquad
    +1 for tyres, bikes always feel better on new rubber, and will give you a better idea of where to start if shocks/forks need sorting.
  4. warren smart
    warren smart Active Member
    Kais suspension do a ride in suspension setup, get it setup for you and it’ll transform the bike.
  5. raphael
    A track day set up will be horrific on the road as the bike will be on its nose making it turn a lot quicker and very very firm.
    I’d go suspension before tyres, ohlins is notoriously hard on the road anyway so will need sorting.
  6. bonjo
    I’d go for suspension check and setup. Roatec are supposed to be excellent touring tyres.
    Get your damping, compression and rebound set properly first
  7. Broadie
    Broadie Active Member
    Check pressures and measure the sag.
  8. Saqib
    Saqib Active Member
    Assuming you have a stock bike.. first thing is to get the owners manual out, and adjust the suspension to the standard settings. Once you have a baseline, then you can adjust from there.
    If it still feels some way off, then consider upgrades. Depending on which end of the bike, a new rear shock or a set of fork cartridges might help.
    I do this on all my new to me bikes. On my Aprillia, I found that the dealer had set my fast and low speed compression the wrong way around, and the bike felt 'off'. I adjusted them to standard, and now the bike is great.
  9. Iain
    Iain Active Member
    I had Ohlin's on my 04 Blade, and it handled like it was on rails. If you can, download the Ohlin's manual and reset all the settings to their standard settings and leave them until you have everything else sorted.
    I found my bike quite sensitive on tyres, Parelli's or Metzler worked well, Bridgestone were stiffer - but it depends on how you like the bike to feel.
  10. LowSide76
    LowSide76 Active Member
    Suspension is a night mare. I have fitted a bitubo race shock to mine and it is phenomenal , just grips and go. Front is a ok but reckon could get it better but o. The bpf only way to do it is a cartridge kit which is pricey. Just a case of keep tweaking settings until you are happy as everybody rides different.
  11. Jez
    I would check the spring rates, on forks they normally engrave them on the top and on the rear spring it is printed on if its Ohlins, I have put the chart on from Brookes suspension.
    • Useful Useful x 2
  12. midders
    midders New Member
    Thanks for all the input, I've decided to go with some new rubber, and hopefully get the guys who fit it to help me reset the suspension.
    Will post back with the results.
    Slàinte
    midders
    P.S. I used to do all my own servicing, maintenance etc. but as I've got older I've come to the conclusion that paying an expert takes a lot less effort.
  13. Coda
    Coda Active Member
    I know where you’re coming from. I tend to not trust others well to do a good job, so I’ve always learned to do things myself. But, as I’ve gotten older I find I have less time and slightly more disposable income. The trick is to identify those times where you ought to let go and trust someone else. I struggle with that.
  14. Broadie
    Doesn't take a lot of time or effort to measure the sag and read the rear spring. This little knowledge could save you being fleeced.
  15. midders
    midders New Member
    Found a local bike shop (where I bought my last 'blade) that has Ohlins trained engineers who'll do a full suspension setup for £99, sounds like the way to go. Just have to wait for the rain to stop...
  16. Iain
    Iain Active Member
    Get them to give you the setting they use, and if possible the standard ones. Then if you feel the need to tweak the settings you have a baseline, and of course you can always go back to them.
  17. midders
    midders New Member
    Yes, I'll get them to take me through everything so I can fiddle a bit if needed.
  18. midders
    midders New Member
    Had the setup done earlier today; it was way off for my weight, in fact the rear adjustment is now maxed out because I don't weigh enough to compress the rear spring.
    Immediate massive improvement over bumpy conditions, though couldn't push it too hard due to wet leaves and uncertain grip. Will do some more testing next time the sun appears and put a softer spring on if I'm still not happy with it.
    Slàinte
    midders
  19. bazzashadow
    bazzashadow Elite Member
    Someone on here( I’m not going to say because their head will get even bigger:rolleyes:)
    Told me to lower the pressure to 36 psi in the rear and not the stated 42psi
    Changed the bike instantly ;)
  20. warren smart
    I run 28 rear and 33 front.
