anyone got one or know of one ? Trying to get the speedo to work, looks like some one has cut the green n pink wire but I can't find out where In the loom !! So need to know if the loom comes from a working speedo bike, which breakers can't/won't confirm
Did it use to have a gear indicator? Good luck with finding one, I tried to get one for my 07 and gave up in the end.
The clocks and lights are on a sub-loom, I think it plugs in behind the upper left fairing panel, close to the diagnostic plug. If you remove the loom it will be easier to locate the cut wires you mention, and repair. Or if you can just replace the sub loom. Not all gear indicators are plug and play some cheaper one's require splicing in. Hope this helps.
