07 Brake Fluid Capacity
Discussion in 'Maintenance' started by Barstewardsquad, Jan 18, 2015.
  1. Barstewardsquad
    I am going to be replacing the front calipers and the rear master cylinder and so will naturally be putting new fluid in. Does anyone know how much I will need? I've checked the Haynes manual, the service manual, and searched on here but can't see how much I will need.
    I'm thinking about using Motul RBF 660 as there will be an occasional trackday. Is this overkill?
  2. sps170373
    When I changed my master cylinder and calipers I only used half a 500ml bottle of brake fluid
  3. Gilesy
    Gilesy Elite Member
    surprised it was that much.. but 1 bottle should get the entire system bled to an inch of its life :)
  4. bambo838
    bambo838 Active Member
    as Gilesy wrote, one 500ml bottle would be more that enough.
  5. sps170373
    I probably pulled through more than was needed but wanted to be sure of no air! First time I'd done it as well
  6. Slick
    Slick Elite Member
    After servicing the calipers and putting on a RCS also had to bleed from dry I used less than 500ml too, lots left over
  7. Barstewardsquad
    Cheers folks. Just ordered 500ml of Motul 660, and if lucky I may have enough to also flush the clutch at the same time.
