08 1000RR - Complete Rebuild - Crash and Fire Damage
Discussion in 'General 1000RR Discussion' started by martin_deyanov, Jun 14, 2018.
  1. martin_deyanov
    martin_deyanov Active Member
    Alright.. so the engine went from this:
    To this (after a ridiculous amount of scrubbing):
    20180428_172610.jpg 20180428_172513.jpg 20180428_172531.jpg 20180428_172543.jpg 20180428_172559.jpg
  2. martin_deyanov
    Painted with high heat paint. It turned out a bit lighter grey than I wanted, but this was the closest to the factory semi-metallic finish. Options were limited, the other was flat black, which I think would have looked worse.
    TBH, I am not sure how good the paint will hold, although I prepped and cleaned the surface as best as I could. Surely it will not be as durable as the factory finish, but hopefully it will bake good enough once it gets up to temp.
    At the end of the day, if it gets messed up, I easily drop the engine during winter, paint with engine enamel and be done with it.
    20180428_182325.jpg 20180428_182330.jpg 20180428_182249.jpg 20180428_182301.jpg 20180428_182313.jpg
  3. martin_deyanov
    Onto the frame, some random pictures of what it looked like prior to paint stripping.
    20180429_145313.jpg 20180429_145326.jpg 20180429_145330.jpg 20180411_222308.jpg 20180429_145244.jpg 20180429_145304.jpg
  4. nigelrb
    Great progress. Paint colour is fine for a track bike. Will even look darker with the fairing on etc.
    Don't be upset, but I actually enjoyed reading the Bulgarian newspapers more than looking at your bike!!:D:D
  5. martin_deyanov
    Paint stripper is nasty stuff, definitely a good idea to work outside. I did consider sending it for sand blasting, however with what was available in my area did not give much choice of media. And they usually use very coarse sand, so I was concerned they will mess up any machined surfaces.
    This is after the first pass. VIN tag was safely removed and will be riveted back in place after painting.
    20180429_160010.jpg 20180429_162043.jpg 20180429_162052.jpg 20180429_162112.jpg 20180429_145924.jpg 20180429_155942.jpg 20180429_160001.jpg
  6. martin_deyanov
    I am trying to catch up with the photos to where I am at the moment.
  7. martin_deyanov
    This is after 3 passes with ps and power wash. Very stubborn in some places. I got tired so finished it up the next day and finally wire wheeled all the leftover paint and oxidized spots.
    I didn't take pictures, but afterwards the frame was masked very carefully - all bolt holes, machined surfaces, headstock bearings etc. and sent for powder coating.
    20180429_164818.jpg 20180429_164826.jpg 20180429_164837.jpg 20180429_164759.jpg 20180429_164811.jpg
  8. martin_deyanov
    Shock and linkage cleaned and re-greased the bushings. Brake calipers being rebuilt.
  9. martin_deyanov
    Engine covers removed. Will be stripped, sanded and powder coated.
    Removing the alternator as it will need some attention too. Alternator itself is fine, but the external wire is a bit burned so it will need to be replaced. Also notice the DIY block off plates on the valve cover made from a steel plate... I will either paint these or have a friend cut out new ones from aluminium, we'll see.
    20180501_211514.jpg 20180501_211554.jpg 20180501_211600.jpg 20180501_211604.jpg 20180501_172111.jpg 20180501_172249.jpg 20180501_180750.jpg 20180501_211353.jpg 20180501_211357.jpg 20180501_211402.jpg
  10. martin_deyanov
    Engine covers, block off plates, lower triple, water pump cover and cylinder block water connection pipe - sanded down, prepped and ready to be masked.
    And finally painted. I think they turned out quite well. Again I wanted to make them a little darker, but still OK. Metallic effect is quite visible and they will contrast well with a matte black frame.
    20180518_003359.jpg 20180518_003324.jpg 20180518_003339.jpg 20180518_003349.jpg
  11. martin_deyanov
    Frame also came back from paint. Masking tape is still on and turned out a bitch to remove under the thick powder coat.
  12. hitch
    hitch Elite Member
    I really like the paint you've used.
    Looks great.
    I cant wait to see how this turns out.
    It's like watching your favorite TV show eager for the next episode o_O
    • Agree Agree x 2
  13. nigelrb
    Won't be long. Martin will have it back together faster than the factory assembly line!!:D
  14. martin_deyanov
    Thanks, but you guys do realize that I have been working on this almost every day for the last couple of months and I am now posting pictures of the whole process :D
  15. nigelrb
    Ah, so that's how the frame got painted so quick!!:rolleyes:
    The old sleight of hand time lapse camera trick:D.
  16. martin_deyanov
    Yep :rolleyes:
    I started taking it apart end of March and was hoping to have it running by end of May. It turned to be much more tedious than I anticipated. I also have a tendency to get caught up in minor details which unless I do exactly as I want them would bother me tremendously o_O Not to mention waiting for parts from Honda requires serious patience.
  17. hitch
    hitch Elite Member
    Hmmm, now that is something a few of us can relate to! ...a case of OCD :oops:
    • Agree Agree x 3
  18. martin_deyanov
    Assembling the water pump I ran into an interesting problem...
    20180518_003947.jpg New gasket - 2 weeks from Honda. :mad:
    Racing front fairing stay (sandblasted), a little tweaked from the crash but will straighten no problem.
    Bolts and other hardware (semi)organized and also 2 crates of various parts and wiring. The fasteners are a combination of what I stripped off the donor bike and what I was able to clean and restore to a good usable condition from mine.
    TBH, cleaning, sanding and restoring the frame, engine, engine covers, bolts and other small parts like the starter motor, water pump, brake calipers, etc. was the most tedious and frustrating part of the whole project. It took me many many hours of scrubbing which left my fingers sore for days.
    Anyways, the dirty work is now finished and its time to start putting it back together.
    #58 martin_deyanov, Jun 21, 2018
  19. nigelrb
    A couple of months ago when putting on one of my numberplates, I somehow mismarked the position about 2mm to the side, thereby leaving the plate off-centre. A professor of mathematics wouldn't notice - but I did.
    You know the result: I ordered a new plate!!:rolleyes:
    • Funny Funny x 2
  20. martin_deyanov
    This is absolutely something I would do.
