08 1000RR - Complete Rebuild - Crash and Fire Damage
Discussion in 'General 1000RR Discussion' started by martin_deyanov, Jun 14, 2018.
  1. martin_deyanov
    martin_deyanov Active Member
    Another day, another set of pictures :)
    Here is the engine as it sits stripped down (valve cover installed). The plan now is to put the engine covers back on, install starter motor, thermostat, speedo and neutral sensors and drop the frame onto the engine.
    20180520_192312.jpg 20180520_192319.jpg 20180520_192346.jpg 20180520_192406.jpg
  2. martin_deyanov
    So, valve cover installed with block-off plates. Clutch cover in place, new seal on the clutch shaft/arm.
    Starter motor, knock sensor, speedo sensor, neutral sensor and intake boots - all in place.
    Notice the Rizoma timing cap on the clutch cover. It has a plastic slider that bolts on top.
    Alternator cover will be left off for now, as the alternator wires need some attention.
    At this point the online parts fiche catalogues come invaluable when selecting the proper bolts. Honda lists the bolts type, size AND length, so it is easy to source through my not-so-organized lot and choose the correct ones.
    20180521_233013.jpg 20180521_233021.jpg 20180521_233025.jpg 20180521_233036.jpg 20180521_233100.jpg 20180521_233129.jpg 20180521_233142.jpg 20180521_233152.jpg 20180521_233202.jpg 20180521_232958.jpg
  3. nigelrb
    Very interesting looking at these. The last motor I saw physically out of a bike was my 1970 CB 750 K1. Whilst all the essentials are just about the same, the refinements are considerable.
    Good range of pics, Martin. As a appreciater of art, I especially enjoy the contrast between fresh paint and rusted drive sprocket.:cool::cool:;)
  4. martin_deyanov
    I was sure someone would notice and comment on that. I would have cleaned it, had I not forgotten to loosen it prior to removing the rear wheel and chain. Since I don't feel like hammering it with an impact wrench while in gear it will have to wait until I put the rear back on and take it off the proper way. I am not really concerned about the sprocket, it will clean right off the first couple of miles, but more about the shaft which I need to clean properly.
  5. martin_deyanov
    And yes, you are right. Looking at the bare engine and comparing to my old 97 blade (which can be seen in the back in some photos) the refinements are huge indeed.
  6. nigelrb
    Yep. There's one in every bunch and it's usually me:rolleyes:;). (Agree with you about the removal)
  7. martin_deyanov
    Frame prepped, masking tape removed, all machined surfaces cleaned, ready to drop onto the engine.
    20180528_191847.jpg 20180528_191854.jpg 20180528_191906.jpg 20180528_191939.jpg 20180528_192000.jpg 20180528_191817.jpg
  8. martin_deyanov
    And finally, engine and frame assembled.
    20180528_215740.jpg 20180528_215757.jpg 20180528_215817.jpg 20180528_215830.jpg 20180528_215840.jpg 20180528_215624.jpg 20180528_215640.jpg 20180528_215652.jpg 20180528_215718.jpg 20180528_215732.jpg
  9. hitch
    hitch Elite Member
    Coming along very nicely.
  10. martin_deyanov
    Thanks Hitch, it is indeed.
    Swingarm, shock and linkage installed. All bolts are loosely in place for the moment, just test fitting everything. Will be tightened down and dropped onto front and rear stands as soon as I have the lower triple in place. As you can see, since I am doing all the work by myself, I had to get creative with supporting the engine / frame :cool:
    It is now starting to resemble a motorcycle again :D
    20180528_222717.jpg 20180528_222726.jpg 20180528_222737.jpg 20180528_222750.jpg 20180528_222800.jpg 20180528_222810.jpg 20180528_222823.jpg 20180528_222842.jpg 20180528_222712.jpg
  11. hitch
    hitch Elite Member
    I was going to say something about the wooden support struts earlier :eek:
    And yes, it now resembles a bike.
    Great work so far
  12. nigelrb
    I wasn't because I could see they were made-to-measure!
  13. Alan-lee
    Alan-lee Active Member
    Lovin this thread
    Makes me jealous id love a good project
  14. martin_deyanov
    Water pump in place. Thermostat mounted and its hoses plugged in. I have put one of the silicone hoses for now, but will probably replace it with a clean OEM hose. I have a complete set coming in. It is perfectly usable, but I don't like the blue, especially being discoloured from the fire.
    20180529_213514.jpg 20180529_234443.jpg 20180529_234452.jpg 20180529_234503.jpg 20180529_234535.jpg 20180529_213504.jpg
  15. martin_deyanov
    Head bearings will obviously be replaced. New races in place in the frame.
    Also there was a bit of crap down in the spark plug holes... obviously cannot leave it like that. Holes were blown out with compressed air, plugs removed and each opening was cleaned with a special tool I made (a screwdriver with a rag on the end :rolleyes:). Sparkplugs back in place and coils installed.
    Thinking about it, I should have probably done all this while I had the engine out of the frame as access was fairly obstructed. Anyways all done.
    Time to tackle the wiring harness.
    20180531_214104.jpg 20180531_214109.jpg 20180531_214121.jpg 20180531_214950.jpg 20180531_215808.jpg 20180531_230627.jpg 20180531_230639.jpg 20180530_231531.jpg 20180531_231641.jpg
  16. martin_deyanov
    First test fit of the wiring harness and first major problem I ran into.
    If you recall, my main donor bike was a 2011 ABS model. The ABS is a completely independent system from the engine management / speedo / controls and starter circuits. So it is not a problem to disconnect the ABS ECU, pump units, sensors etc. and connect the brakes directly to the master cylinders, thus eliminating the whole system. Therefore the wiring harness can be connected to a non-abs bike, leaving all unused plugs disconnected and it will work.
    Problem 1 - the ABS sub loom is substantial (maybe 50% compared to the main loom) and integrates the power connector to the starter solenoid, thus it cannot be completely disconnected. There are 4 (or 3, dont remember) very large connectors for the ABS ECU with a lot of wires, so it is a pretty thick harness. So I either will have to live with a bunch of unused wires or chop it down to the essential wiring and cut the rest off. I didn't like it either way.
    Problem 2 - While the engine / front side of the loom is identical in shape to the non-abs bike, with the exception of a couple extra connectors for the ABS sensors, the tail section arrangement is COMPLETELY different. I ended up buying a mint subframe tray (non-abs) off Ebay and there was no way to arrange the ABS loom, battery, starters solenoid, rectifier and fuse box in a non-abs undertray. Probably could make it fit with a lot of chopping of both the tray and the harness, but this is again something I didn't want to do.
    So I had to either source an ABS tray (which in fact is a lot deeper/bigger to house the extra ABS pumps, etc.) or source a non-abs loom.
    Guess which one is cheaper and more readily available in good condition?
    20180602_021434.jpg 20180531_235426.jpg 20180531_235435.jpg 20180531_235448.jpg 20180531_235451.jpg 20180531_235420.jpg
    #76 martin_deyanov, Jun 25, 2018
  17. martin_deyanov
    As I was saying ;)
    20180616_172052.jpg Left is the ABS, right is the non-ABS, which was sold to me as an 08, but turned out to be a 15 loom. More on that later.
    Other parts came in as well - frame sliders, front master (gold cap is going away, as I have another reservoir), brake lever, right clip-on, front sub-loom (for the speedo and headlight), Renthal grips and some other small bits.
    20180616_172829.jpg 20180531_182714.jpg 20180614_203519.jpg 20180616_172003.jpg
  18. martin_deyanov
    Can you guess what that is?
    20180616_221918.jpg 20180616_221923.jpg 20180616_221934.jpg 20180616_172120.jpg
  19. nigelrb
    If it doesn't get polished, I know nuthin'.:D
  20. martin_deyanov
    Heh, it did get polished and wrapped, prior to connecting. Sadly I forgot to take pictures :oops:
