08 1000rr headrace removal
Discussion in 'Maintenance' started by Nostromo, Aug 9, 2020.
  1. Nostromo
    Nostromo New Member
    After watching some vids online, I think I’m going to undertake this myself.
    My question is, can I knock out the old races using a flathead screwdriver? Or is there a special way to do it?
    cheers
  2. Muffking
    If you have good access from above and below then any drift will do that doesn't damage the surface of where they mount. I use a solid round metal bar, but a big ass screwdriver should do.
  3. Nostromo
    Nostromo New Member
    Cheers
  4. 1000rrboyjay
    1000rrboyjay Active Member
    How did it go?
  5. Nostromo
    Nostromo New Member
    Haven’t had chance yet, got myself a set of black yokes to go on though, hopefully get to do it this weekend.
  6. Kentblade
    Kentblade Elite Member
    Get yourself a driver or puller kit, having spent years removing bearings using all kinds of screwdrivers etc, it’s just easy with the right tool as always
  7. 1000rrboyjay
    nice. Black looks much better
  8. Nostromo
    Nostromo New Member
    All done, main issue was the rounded of bolts on the ignition barrel, @Kentblade i think I will invest in a kit as I’ll be doing the Ducati next and another project after that. I used the back of an old torque wrench(hex end) and that did the trick. Black triples look miles better aswell. E7F9FD59-131C-4E4F-BDEA-5AB6198B2E1B.jpeg 953B68D0-ABEC-44DC-905E-43B3E03CB91C.jpeg
  9. 1000rrboyjay
    Black looks so much better agreed. Next you’ll want the black clock surround from an 11 Repsol
  10. 1000rrboyjay
  11. Nostromo
    Nostromo New Member
    This is now on the list!
  12. 1000rrboyjay
    I also like cherry coke
