Here is my nitron shock. It was nitrons devolopment shock and it was used at the tt.. Beautifully made and comes with a titanuim. Awesome handling and tyre wear .. Phone nitron if you'd like to discuss it..excellent used condition with no damage . Remote prload adjuster was removed but can be added for Around 100 pounds. Came off nuttys Carbon cracker so no doubt she will fill you in. £425
Dang just checked with Nitron for fitment to an ABS and the computer said nooooo.. Otherwise would be all over this!! Am sure this will be taken off you hands very quickly!
It Should fit slick.. They advise no because of the abs gubbins in subframe.. All shocks are the same i thought. It's s nice thing to be fair and thought 400 was a fair price. I'm goikg Ohlins to match the 30mm in the front
I checked with one of the tech guys a Nitron. I did mention that the Ohlins equivalent is the same for both the non and ABS models but apparently the ABS 'nappy' gets in the way. They have built bespoke solutions for the ABS where the reservoir is connected via a hose. Your bike is gonna be a beast!
Cheers for the heads up slick .. I'll give you. Run down of the spec so far . It's bkoody mouth watering Bst carbon wheels Rear underslung brembo and floating disk Pvm 6 pot clippers and narrow band floating disks Bst carbon wheels Rear underslung brembo and floating disk Pvm 6 pot clippers and narrow band floating disks Hel lines Kit loom Kit ecu Samco hoses Full factory akro ti sytem Pc5 Gilles rearsets Gilles chsin adjusters Brembo RCs 19/20 mc Brembo clutch perch Carbon clipons Onlins 30mm kit Carbon fairing stay Hrc bell mouths Mwr filter Gb protection Gilles brash protection Carbon Kevlar tt kegends fairings All bolts are Titanuim Got a hm ss shifter to fit and a gpr damper Hm dash imminent Aswell as ttx gp shock Brembo down adjuster and Carbon frans and swingarm protectors .. Can't wait to get it out on track
The bell mouths Are good yeah. If you have done the exhaust , air filter etc and start wanting to add power without engines mods they are worth the 300 quid. Defo improve overall torque tho. Needs s remap to gain best benefit so if your doikg anything else wait till your all done and get a map some for joblot
Yeah it's on ebay now. Sticking to the original plan of hsving an Ohlins to Match the 30 mm kit in the front
