08-16 SP subframe in Black. Believe it fits both ABS and non ABS models but please double check? £180 posted. Underslung rear caliper bracket. Can be used with oem wheels but requires the use of the more expensive billet brembo caliper. £65 posted.
Hi tuktuk, for information, I fitted a SP subframe on my nonABS 2010 blade and everything worked fine Where does the underslung bracket come from please ? It is for 84mm calipers ?
Cheers. Yeah 84mm spacing. Im told it was originally imported from America. Not sure if there is any info out there for Agras?
Yeah sorry, just saw the Agras logo after posted my message looks like a little japanese manufacturer I'm currently looking for the Ladybird one to fit it this winter, but I always prefer good condition second hand products than brand new ones It was mounted on your bike ? So 100% OK it works with 2008+ wheels ? Do you ship to France please ?
I cant say 100%, I was told that the cast brembo will foul the oem wheels but the billet does not. I will try and find the pic I seen showing this. I had it on the bike but not with a caliper or wheel attached so no help at all
I would like to mount it with this caliper https://www.carpimoto.com/EN/51047_...nium-Red-Coated-Brembo-Logo-07BB2035-pads.htm It's annoying to don't find any informations on google :/ looks like it is a well done stuff
Those ones will work with aftermarket wheels but not oem. You would need the billet one like the below link. https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/272846490877 This is the reason I'm looking to sell as for a bit of bling it was worth buying the cast brembo caliper but I dont use the rear brake enough to warrant 400 quid on a caliper when the M4s on the front cost similar for a pair!
Unfortunately we are in the same situation :/ I just want to add a little bling to the bike so the 400€ caliper is not an option for me I think :/ Thanks for all of your informations tuktuk !
