08+ mirrors.
Discussion in 'Wanted' started by FirebladeRR, Oct 17, 2014.
  1. FirebladeRR
    FirebladeRR Active Member
    I will do a search. Pm me when you decided.
    Ps how can I find the video on YouTube?
    #21 FirebladeRR, Nov 19, 2014
  2. Chriscbr
    Chriscbr Active Member
  3. FirebladeRR
    Ok. Are they plug and play?! And obviously foldable?
  4. Chriscbr
    Yes but you will need to drill a hole under the mirrors see tripage website then link in to the std indicators via a y link which i might have not sure. I had to cut plugs off as i did not want to drill a hole bigger than 8mm. Then resolder them together . Then for the running lights you need a live feed
  5. FirebladeRR
    Mmmmmm...... I don't know. How did you wire up the running lights yourself? Do you remember? Well let me know when you check to see If you have the y plugs. Obviously you had to cut them again when you took it off as well?
  6. Chriscbr
    Yes I did . The other bike was a cbr600F so it would be different to yours. Its just one wire to any live. I used the one for the sidelights. They do get you noticed as they are very bright running lights.
    Chris
  7. FirebladeRR
    i might be wrong but I was 90% sure indicator connectors were the same on those Hondas so don't think they are different. Anyway pm me when you decide on a price and if you have y links and i will see.
  8. brg1000
    brg1000 Active Member
    I have the main part. The frame and mount with the mirror glass. Left and right £25 each
  9. FirebladeRR
    Thanks mate. Just waiting to hear back from chris then I'll let you know as his setup is fuller.
