Hi guys After my first blast in anger on blade on Saturday only got it in November Found a intermittent problem after riding and switching bike off when go to start it won't start and can't hear the fuel pump priming a quick flick of the kill switch on and off sorts it out As I said doesn't happen all the time Thinking a new kill switch needed ? Have checked the connections and all seem fine Bike only has 1600 miles it Any ideas if it's summit else chaps If needing a new kill switch how much am I looking at had thought about contacting Yorkshire gooner on here to see if he had any and what price was looking at Many thanks Brian
yorkshiregooner will have one, and I don't think it'll be that expensive. How do you turn the bike off? with the kill switch? or key? if with the kill switch, try only using the key for a bit until it happens again. if it doesn't happen again then buy yourself a new kill switch. If it does happen when using the key then it's not the kill switch and I have just saved you 20 odd pounds or so but we'll have to look further.
Hi skippy Always use the key for on and off very rarely use kill switch but my thinking it was kill switch is that when I switch it off and on puts the problem right Cheers
If the bike has been sat for the winter it may have some corrosion/moisture inside, open it up and have a look.
