1000rr6 wheels/breaks
Discussion in 'Wanted' started by JayBee, May 17, 2017.
  1. JayBee
    JayBee New Member
    Looking for a set of wheels for my Honda cbr1000rr6. I been told a couple of years fit that bike, apart from the 07 not sure wat else. Also looking from some Brembo break parts, from disks, callipers to marster cylinder.
  2. Muffking
    I can't help with the parts, but the RR4/5 & RR6/7 wheels are the same without messing around with spacers.
    The front discs are different between RR4/5 vs RR6/7 though.
  3. JayBee
    JayBee New Member
    Thanks for that!! And I take it u can use the rr6-7 disks on rr4-5 wheels
  4. Muffking
    Yep.
    Or you can use rr4/5 discs as long as you remove the spacers on your calliper bolts as the discs are around 20mm smaller.
  5. Iain
    Iain Active Member
    As it happens I have a set of 04 wheels and disks taking up space in the garage that I keep meaning to do something with.
  6. zxrob
    zxrob Active Member
    VTRSP1 and 2 front disks are the same as 06/07 blade one
    Cheers Rob
  7. JayBee
    JayBee New Member
    What's ur going price then? And where u live
  8. JayBee
    JayBee New Member
    Thank u Rob I'll look into that
  9. Iain
    Iain Active Member
    JayBee, if that question was aimed at me, then I am in Poole, price I guess will depend on what it is you want. At the moment, the wheels have disks fitted and tyres with some life left on them. Not sure how you PM on here, but if you figure it out, let me know, or maybe someone else can help!
