12v socket on fireblade 2017
Discussion in 'Mods, Upgrades, Accessories and Products' started by Ice Doc, Aug 6, 2019.
  1. Ice Doc
    Ice Doc Active Member
    So my week of trying to do useful stuff seems to be going pretty badly. Firstly the rear footrest blanking plates didn't turn up, and now the mini tyre compressor I bought to use with my bike has blown the 1A fuse in my 12V accessory socket on my blade. I've replaced the fuse, but I'm now wondering why Honda sell a 12V accessory socket kit which supports a maximum of 1A only. The 12V pump needs 5A apparently.
    How do others get around this - I was hoping to have a pump I could use to re-inflate my tyres after my track day next week (as I've been advised it's good to lower the pressure for the track).. Do I need to find a weedy compressor that uses less than 1A, or take a foot pump?
    Ho hum..
  2. bazzashadow
    bazzashadow Elite Member
  3. edderby
    edderby Active Member
    I have a Stop and Go puncture repair kit with compressor. It plugs directly into the battery via my optimate charger cable - nice and simple solution.
  4. edderby
    They are £50 on eBay from Busters (compressor and all the puncture repair stuff)
  5. Spygoat
    Spygoat Well-Known Member
    Most tracks have an air station. At least here in the USA they do.
    However, you will find some very helpful people at a track day and iff you asked to use their compressor, they will very likely let you!
  6. Ice Doc
    Pump looks like the same as the one I got, so maybe all I need is an adapter that connects directly to my bike’s battery rather than via the 12V socket (that is limited to 1A). I was wondering if there was a low powered pump (12W I guess).
  7. Barstewardsquad
    If you have a trickle charger then just get a pump, or modify a lead, that can plug in to the connector on the bike.
    1 amp is as much use as tits on a fish. Most phones now charge at 2.4a or more. 1amp gives you 12 watts of power which is pretty much equal to the square root of eff all.
    Unless you are running significantly lower pressures on track then you can simply ride it on the road the nearest petrol station, or as suggested simply ask someone at the track for a bit of air/power.
  8. willb
    willb Active Member
  9. Ice Doc
  10. nigelrb
    Now that just depends on da fish ya hookin' my man . . .:D:D
  11. nigelrb
    Oh goody. I'll watch out for some downvotes next week!!:D:D;)
  12. Ice Doc
    Well it'll be arriving in time (I hope) to take with me to my track day at Brands Hatch on Thurs, so if I'm still alive after that I'll be able to provide an update on its performance. I'm planning to let a few psi out at the start of the day and then use it to stick a few back in at the end of the day so it'll definitely get tested. More soon..!
  13. roboticus
    roboticus Active Member
    I got a similar one from aldi, there mint, you'll be able borrow one anyway if it don't come, 30 front 32 rear, give it a couple of laps before u ring its neck, if its no limits they did free training for novice at oulton, so ask them,
  14. Barstewardsquad
    Now you're being silly. That is a Mermaid and not a Fish, next you'll be saying that a Unicorn is a Horse :p
  15. willb
    willb Active Member
    :eek:!!!
    One thing it took me forever to realise (simple idiot I am), is there is no charge indication on the unit itself. There is a colour LED on the charge plug to indicate when charged. Doh!
