2005 fireblade leaking oil!
Discussion in 'General 1000RR Discussion' started by JA3llis, Jun 22, 2015.
  1. JA3llis
    JA3llis New Member
    Evening all new on here and after a little advise. I baught a 2005 1000rr yesterday from a dealer. The blade has 11k on and full history. I picked the bike up yesterday and it ride as sweet as you like. Im a mechanic by trade so when at work today i decided to have a close look behind the fairings while i still have warranty on the bike. Iv noticed a small oil leak behind the n/s/f fearing and i carnt work out what the part thats leaking is? Its a shaft with teeth on it that has an arm pressed on it thats then bolted to the block anyone have any ideas? Many thanks in advance
  2. Dave
    Dave Member
    I'm guessing it's the crank balance shaft, definately back to the dealer for warranty claim:(.
  3. JA3llis
    JA3llis New Member
    I guessed it was balance shaft it was only thing i could think of
  4. Kentblade
    Kentblade God Like
    Where in relation to the sump is the leak?
    Is the sump covered in oil?
  5. JA3llis
    JA3llis New Member
    Its above sump on the lhs if sitting on bike there is misting on sump but the drip is definitely coming from behind the shaft that comes through the crank case
  6. Kentblade
    Kentblade God Like
    That's good mate, the RR4 to 7 suffered with galvanic corrosion around the sump plug that ate the mag sump away due to using the incorrect sump washer, yet another design feck up Honda washed their hands of.
  7. JA3llis
    JA3llis New Member
    Nice another great idea im guessing to remove the balancer shaft to replace the £2 seal is to split the cases?
  8. ShinySideUp
    ShinySideUp Elite Member
    Wait wait wait...........so Honda have made design mistakes in the past and don't want the expense or even to acknowledge they fecked up..........well I never, oh well at least they don't make mistakes when it's possibly a life threatening issue..........oh sh#t wait a minute!!! :D
  9. scooby
    scooby Elite Member
    yep.
    just take it back,show them and tell them to sort it.job done.
  10. JA3llis
    JA3llis New Member
    Massive thanks for the quick replies one of the best forums iv ever been on. Thanks
