This shock is totally mint having been taken off a new Blade SP in 2016 which was turned into a full blown Super Bike with Kit pretty much everything. The shock has about 30 miles of light road use just shaking out the bike prior to full race prep rebuild. The Shock has had the Ohlins recall work done and so mechanically its perfect inside and out. It has the preload adjuster on the bottom which makes it harder for idiots to adjust on you. Its presently sprung for a 11- 16 stone rider (without kit) but if you are a bit lighter or a bit heavier you will be fine. The retail shock is £1300 new. buy this for just £600 OVNO. Barry. 07921 849 076
