2008 passenger peg fitting
Discussion in 'Maintenance' started by bm69, Sep 15, 2018.
  1. bm69
    bm69 Active Member
    Anyone got any videos or tips on fitting passenger pegs to 2008 1000rr. Went to fit mine today and looks like it could be a big job.
    Seen one video online where where the guy has the petrol tank off. Surely there's an easier way.
  2. Voleracing
    Voleracing Active Member
  3. nigelrb
    There is good instruction about removing the sub frame. I used this:
    https://trinityzxr750l1.blogspot.com/2014/01/fitting-sato-racing-street-hooks-to.html
    As 'Vole' says, up to one and a half hours for a first-timer. Pain in the ass, but well worth it. Even if you're not using street hooks, the disassemble and assemble is the same. Beware though, that ABS models are a tad different in that the battery is sited differently, and there is less working room above the rear wheel.
  4. bradt
    bradt Elite Member
    Took the pegs off my 9, easy enough job if you follow the instructions found on the forum and you tube as suggested allow a couple of hours to do the job.
  5. nigelrb
    Of course that has to assume that @bm69 is as accomplished with tools as are you!:D
    • Optimistic Optimistic x 1
  6. Bikeboy
    Bikeboy Active Member
    I did mine. Took 40minutes . Just follow the vids. Its easy enough it'd just a lot of work to remove them when you consider another bike would take 2 mins . 20180810_203112-3024x2268.jpg
  7. Bikeboy
    Mines not Abs
  8. nigelrb
    Bloody hell, @Bikeboy . You been hittin' dem wet roads agin?:D
    Nice clean sprocket though!!;)
