Hi all, I have a 2008 blade with a 2011 engine. It has been a race bike all it's life apparently. I have owned it 6 months. When I bought her she had a Translogic dash fitted. Having never managed to get the gear position indicator working & wanting the GPS laptiming facility of a HM Dash I have bought one of a friend (dash is known to work fine on his Fireblade) for a good price... The problem I have is the rev counter isn't working....So I have borrowed a standard set of clocks...And the rev counter doesn't work on those either! At this point I have to conclude that the Tacho Signal to the clocks is faulty.... I believe this is the Yellow/Green wire to the clocks. When I test this from the clocks sub loom harness the connection appears to be a little bit intermittent, hence I have two questions if anyone can help: 1) Is there a way to "test" for a tacho signal? i.e. Can I do this with a standard multi-meter or do I need an oscilloscope or some other fancy piece of equipment? 2) If I suspect the "pin" connector (female) in the small multiway connector that plugs onto the back of the clocks, is there anyway to remove a single pin to check it? This is driving me nuts now so any help / guidance is very much appreciated. Thanks, Keith A
There is a 10amp fuse that causes an issue. Also the clocks connect to subloom near the radiator so could be a loose connection https://www.1000rr.co.uk/threads/help-re-dash-and-rev-counter-not-working.8627/page-2
