2009 CBR1000RR Project bike
Discussion in 'Bikes For Sale' started by si1000repsol, Oct 29, 2019.
  1. si1000repsol
    I have decided to sell my bike and all the parts for the bike. I have not started it for around a year and sadly just don't see that I will get the time to finish it. It will make an amazing project bike for someone.
    At present the bike is a stock engine but have a spare ported head, New Cosworth pistons, HRC Cams and HRC Springs to transform the engine. I have the HRC Gearbox, Clutch and Deep Sump to finish the setup
    I have pretty much most HRC parts available for the fireblade.
    Looking for offers around £12.5k for everything. collection from South London
    The list is not exhaustive as I have have many duplicate titaniumd bolts etc.
    Items are described as fitted (on bike) and not fitted (In a box. Some items are new and some used)
    2009 CBR1000RR with around 3,000 miles - V5, Personalised plate, 2 keys, NO MOT, NO FINANCE NEVER BEEN DROPPED , CRASHED OR RACED (Bike was even featured in Performance bikes magazine)
    Currently in street setup with 2015 Repsol fairings with custom 09 tail with a Carbomoto Carbon fiber undertray and number plate (Tail piece painted trim Needs tidying)
    Datatool Red alarm fitted with 2 key fobs
    Front wavey disks currently fitted (both need replacing as buttons have worn the carrier)
    Brembo supersport front discs to replace the wavey disks
    Stock Radiator needs testing (I have not started it for around 12 months)
    Marchesini Genesi M7RS wheels in Orange direct from Marchesini
    Titanium stock front spindle fitted to the bike
    HRC Front MEL (to fit stock wheels) Spec front Spindle (brand new and never been fitted)
    Pull cups for front HRC Spindle not fitted
    FGRT803 Ohlins front forks 8.5 fitted (I believe)
    Additional ohlins 10.5 springs for front forks
    HRC Steering Damper fitted
    HRC Steering Damper brackets fitted
    HM Dash 10hz version with GPS - New Screen fitted by HM Racing
    HM GP Quickshifter fitted
    Honda Racing (Ex Bathams) stock style tank anodised black fitted
    Honda racing rearsets (£300) ex RAF reserves fitted
    HRC Fuel pump lowering kit for tank (Ex Bathams) fitted
    HRC Throttle bodies very rare not fitted as can only be used with HRC ECU and assist with engine braking
    HRC ECU for 2009 not fitted
    HRC Front Clock bracket not fitted
    HRC Bottles and hose not fitted
    HRC Stock 08 clock not fitted
    HRC Tilt sensor not fitted
    HRC 2 button control handlebar switch not fitted
    HRC SBK oil sump and gaskets not fitted
    HRC Oil pressure relief valve not fitted
    HRC Thermostat not fitted
    HRC Oil Catch tank fitted
    HRC Oil cooler new boxed not fitted
    HRC Clutch cable not fitted
    HRC Clutch plates new and not fitted
    HRC Clutch new boxed and not fitted
    HRC Gearbox P1&P2 not fitted
    HRC Subframe with all fittings with Ti bolts not fitted
    HRC Swingarm fitted
    HRC MEL shock linkage and titanium bolts
    HRC Showa rear shock with ohlins spring not fitted
    HRC Generator cover, gasket, rotor not fitted
    HRC Spark plugs not fitted
    HRC loom and ancillaries not fitted
    HRC Rear spindle new and not fitted
    HRC USB adapter not fitted
    Brembo RCS19 with Carbon bracket fitted and Titanium bolt
    Brembo clutch lever for stock bracket fitted
    Brembo M4 front brakes fitted with rare Hollow Titanium bolts for weight reduction
    HEL Front brakelines with rare TI joints fitted (HEL stopped making TI brakelines)
    Harris 1" raised clip ons fitted
    Harris standard clip ons not fitted
    Honda racing bar ends to fit stock weights not fitted
    Evotech Honda Racing Front clock bracket as used by Swan Honda for motec dash not fitted
    Honda Racing modified HRC Clock Bracket for motec dash not fitted
    Renthal Sprockets one fitted and spares
    SP Subframe powder coated black fitted
    Titanium swingarm Spindle fitted
    Titanium HRC stock rear spindle (wider than stock) fitted
    Ten kate velocity stacks fitted
    Ten kate gear rod linkage fitted
    MWP air filter fitted
    Honda Comfort seat fitted
    Ohlins ttx rear shock with remote adjuster bracket and rare silver adjuster fitted
    RCS Titanium Shock Spring. fitted
    Electrex Generator (Fits HRC Cover) and rotor not fitted
    Titanium engine frame bolts made by TI64 using WFR Honda BSB bikes as template fitted
    Honda racing clipon bars not fitted
    Brembo 84mm rear brake and underslung bracket fitted
    2 x HRC Radiators battered and untested. not fitted
    Akrapovic full TI system inc end can fitted
    Akrapovic longer mid pipe not fitted
    Akrapovic additional can with baffle (Needs new carbon cap fitting) not fitted
    New Akrapovic cap for above can not fitted
    Spare Akrapovic strap not fitted
    Spare Akrapovic Blind rivets and bands not fitted
    Racing fairing brackets inc Honda racing qr brackets not fitted
    General Provbolt Titanium bolts on frame and ancillaries fitted
    08-12 Samco orange hoses fitted
    Akrapovic/Honda Racing Carbon Front mudguard painted pearl Siren Blue fitted
    Gilles gearshaft support fitted
    Gilles TI Rear wheel and Swingarm bolt fitted
    Probolt Ti Cylinder head cover bolts not fitted
    Probolt Ti Cam adjuster bolt not fitted
    Probolt oil Ti sensor bolt fitted
    Probolt oil Ti Filter bolt fitted
    HRP Alloy Cylinder head cover bolts not fitted
    Ti Exhaust Nuts and studs fitted
    Custom Ti Side stand spindle and nut fitted
    Factory Pro Shift kit not fitted
    HRC QA throttle not fitted
    HRC Front wheel sensor,wheel rotor and cables not fitted
    Braketech Axis Full Floating rear brake disk
    Other items
    Rectifier brackets to fit rectifier over the generator
    CRC Upper and Lower race fairing with Hibre Tank, tail and seat cover (Upper and lower requires a repaint)
    Honda Racing fairing parts damaged and used
    Honda racing carbon mudgards x 2 as used on HM Plant TT bike 2008
    Repli-cast Honda Racing carbon test fairings (tank and tail unit 2016) used by Jason O'Halloran
    Honda racing rear wheel guide bolts over the sprocket
    Honda racing chain guide (with spares)
    GB Racing covers with Honda Racing branding
    Easi Grip Tank pads (Honda Racing Spec) as used on 2014 TT Bikes
    Foam Fuel cap holder to spec used by John Mcguiness on 2009 TT Bike
    QR fuel line
    Stock Swingarm
    SP top Yoke
    Honda Racing top and bottom yoke replicas of the 2009 CBR1000RR Honda Racing TT Bike
    #1 si1000repsol, Oct 29, 2019
  2. Bikeboy
    Bikeboy Active Member
    That's some project :cool:
  3. nigelrb
    And ambitious.
    I just cannot see money being recovered on this. That's a massive ask of £12,500 for a 10-year-old bike - despite all the goodies included. I am wondering if even selling parts separate would nett that amount? Just my opinion of course; not wishing to bring doom and gloom to the forum.;)
  4. si1000repsol
    Thanks mate. I am open to offers :)
  5. Barstewardsquad
    GLWS
    Would hate to have to list that lot every years at insurance renewal time.
  6. si1000repsol
    Updated list
    Comes with the V5. Undamaged silver frame,
    Personalised plate Repsol related number plate
    2 keys plus basic key
    Datatool Red alarm with 2 key fobs
    NO MOT
    NO FINANCE
    Currently in street setup with 2015 Repsol fairings (Requires replacement stock undertray, tail trim and cowl)
    Front Galfer wavy disks currently fitted (both need replacing as buttons have worn the carrier) so will need removal
    Marchesini Genesi M7RS wheels in Orange direct from Marchesini with SBK front TI bolts
    R&G front and rear spindle protecters with custom titanium rods
    Titanium stock front spindle fitted to the bike and Titanium nut
    Alloy Pull cups for front and rear HRC Spindle not fitted
    Ohlins HO888 ttx rear shock with remote adjuster bracket and rare silver adjuster fitted
    Ohlins FGRT803 front forks 8.5 fitted (I believe)
    Honda Racing (Ex Bathams Honda BSB) stock style tank anodised black fitted
    Honda Racing rearsets (£300) ex RAF reserves fitted used in BSB and TT
    HRC Steering Damper brackets fitted designed to reduce flex.
    HRC Fuel pump lowering kit for tank (Ex Bathams Honda BSB) fitted
    HRC Oil Filller cap fitted
    HRC Gearbox P1 & P2 not fitted
    HRC 2009 inlet and exhaust Camshafts with a full set of HRC Springs
    HRC Swingarm fitted
    HRC Quick release rear spindle new and not fitted
    HRC Front wheel sensor,wheel rotor and cables with spare sensor cable
    HRC Generator cover
    HRC Generatior rotor for 2008-2010 model
    Brembo supersport front discs to replace the worn out wavy disks
    Brembo RCS19 with Carbon bracket fitted and Titanium bolts
    Brembo smoked front brake reservoir
    Harris standard clip ons not fitted similar to ones used on Honda TT bike
    SP Subframe powder coated black not fitted
    Titanium custom swingarm Spindle fitted and based on HRC version
    Ten kate alloy velocity stacks fitted
    Ten kate QR fuel line
    Ten kate Rectifier bracket
    Ten Kate blockoff covers
    Ohlins HO888 TTX rear shock with remote adjuster bracket and rare silver adjuster fitted
    Electrex Generator (Fits HRC Generator Cover) Electrex rotor and its own rectifier not fitted
    2 x HRC Radiators battered and untested. (1 stock size and 1 larger)
    Akrapovic full TI system inc end can fitted as used on TT and BSB bikes
    Akrapovic longer mid pipe not fitted - slightly longer version
    Akrapovic additional can with baffle for track days (Needs new carbon cap fitting) not fitted
    General Probolt Titanium bolts on frame and ancillaries fitted
    Samco orange hoses fitted for 2008-2010 models
    Gilles TI Swingarm bolt fitted
    Factory Pro Shift gear shift kit not fitted to make gear changes smoother
    Braketech Axis Full Floating rear brake disk and Titanium bolts
    Other items
    Rectifier brackets to fit rectifier over the generator (1 alloy and 1 Carbon Fibre)
    Honda Racing lower fairing cracked and requires repaint
    Honda Racing Endurance tail with LED light used
    Honda racing rear wheel guide bolts over the sprocket as used on TT bike
    Honda racing chain guide (with spares) as used on TT bike
    Honda racing clipon bars not fitted as used on TT bike
    Stock steering damper
    Thermostat housing
    Stock rear brake
    Stock Swingarm
    SP top Yoke
    Woolwich Tuning USB adapter and bike harness
    Honda CBR1000RR ported cylinder head confirmed by JHS Racing (Part of 5 engines built with Wisco and HRC Cams)
  7. Shauncatt87
    Shauncatt87 New Member
    Morning Si, I’ve pm’d you about the silencer I’d like to buy from you, willing to pay really good money for this silencer and carbon strap, I’ve been searching and ringing people, it will finish of my McGuinness replica you’d be helping me out a lot. Please let me know. See picture attached.
    #7 Shauncatt87, Jan 27, 2020
  8. Chris620
    Chris620 Active Member
    Have you still got the HRC oil pressure relief valve for sale?
  9. Zapada
    Zapada Active Member
    Hi do you still have the steering damper and brackets?
