2009 Standard brake upgrade
Discussion in 'Mods, Upgrades, Accessories and Products' started by hoggyjay, Jan 11, 2015.
  1. hoggyjay
    hoggyjay Active Member
    Hope everyone had a good New Year.
    My question is this - Would 2013 Monoblock callipers be a significant improvement over the 2009 standard ones? They will be fitted to a track bike where brake fade is a real possibility.
    All the best,
    Hoggy
  2. Slick
    Slick Elite Member
    wouldn't have thought so as they are the same spec. Unless the condition of the old ones had deteriorated, e.g. seal and corroded pistons causing excessive drag I don't think fade would be reduced.
    You probably need more track specific pads.
  3. N1xxl
    N1xxl Member
    IMO SBS DC pads after initial bed in and warm up they are awesome even in the wet, also did a few races on EBC HH pads and they worked for me. Brembo m/c first upgrade if you go for mods.
  4. sps170373
    Have you changed to braided lines? That and change of mc would be my first changes if I were you
  5. Souleh
    Souleh Active Member
    Master cylinder and lines first :) that should stop your fade
