2011 Blade left hand switch gear removal
Discussion in 'Mods, Upgrades, Accessories and Products' started by RepsolRuss, Dec 7, 2014.
  1. RepsolRuss
    RepsolRuss Active Member
    After a bit of advise guys.
    I'm wanting to remove the left hand switch gear on my 2011 Blade track bike. Is there a resistor kit I need to plug in to the loom so the bike will start once the switch gear has been removed?
    Also, is there a similar thing for the side stand switch?
  2. Scott
    Scott Active Member
    i did notice that gibbons on your bike. there is no clutch switch i don't think. been a long while. the side stand switch, twist em together if i remember correctly
  3. wedgiewolves#223
    wedgiewolves#223 God Like
    Just done mine removed complete left switch and wires for clutch switch . Side stand twist together and tape up
  4. RepsolRuss
    Cheers guys. I'll joint & tape the side stand switch up.
    The bike will start with the left switch gear and clutch switch removed?
  5. wedgiewolves#223
    Yeah fine
  6. RepsolRuss
    Hmmmm tried to start the bike with the left hand switch gear removed and the side stand plugged back in. Didn't want to start. Am I missing something?
    #6 RepsolRuss, Dec 7, 2014
  7. Scott
    Scott Active Member
    Mayb
  8. wedgiewolves#223
    Mine runs fine have you joined the wires to create a loop on side stand ?
  9. RepsolRuss
    Yesterday I had to plug the side stand and the left hand switch gear back in to start the bike. Won't start with just the side stand plugged in. It's stummped me tbh. With my S1000 I had a resistor kit that had to be plugged in to various open connectors to fool the ECU in to thinking everything was connected..
  10. Scott
    Scott Active Member
    Fiddle fiddle fuckked ;)
  11. Pitcrew1
    Pitcrew1 New Member
    Every blade I've built I just remove the left side lights switch completely and if removing the stand, just shorted out the two wire connector, but if you leave the stand switch plugged in make sure the switched is in the closed circuit position (stand up).
  12. RepsolRuss
    Cheers guys
    Iv found the problem............ Wait for it................ I'm a massive d**k head.............. Bike was in gear............ THATS why it didn't want to start lol. Put bike in to netural, removed left hand switch gear and she fired up straight away lol
    For the side stand switch, I cut the cable off the side stand leavening approx 1inch of cable and the connector. Twisted & soldered the cables together then heat/shrink wrapped both cables. Plugged back in to the loom. Works a treat!!
    Happy days
  13. Scott
    Scott Active Member
    Well done fool ;)
    Edit,,,iv done worse
  14. Garyb
    Garyb Moderator.
    Numpty award nomination is imminent, wait until Alblade gets you ;)
  15. RepsolRuss
    Ha ha. Sometimes you can't see the wood for the trees lol.
  16. Daznorthwest
    Daznorthwest Elite Member
    I was turning my bike over in September and wondered why it wouldn't start.. Didn't have the tank on ha
  17. RepsolRuss
    Ha ha thanks mate. That's made me feel much better lol
