2012 ABS R&G Rear Hugger
Discussion in 'Mods, Upgrades, Accessories and Products' started by mikesouthby, May 2, 2015.
  1. mikesouthby
    mikesouthby Active Member
    I'm think of getting one of the R&G rear hungers for my 2012 ABS, has anyone got one? thoughts?
    Be really appreciated if you could post up some pictures if you have one fitted, thanks :)
  2. RRoss
    RRoss Active Member
  3. RRoss
    RRoss Active Member
    I really fancied the HRC carbon one to match the front but I'd heard of people cracking them off the abs unit:(
    Got this instead,fits well,kinda matches in with the abs unit and def no contact between them:)
  4. BladeJogger
    BladeJogger Member
    Got one on my 2012 abs blade,looks good,but was a total pain to fit,in fact I think it's only got two of the three bolts fitted as I couldn't line it up with the pre-drilled holes.Saying that it's rock solid and has been on nearly two years.
  5. sps170373
    I had one before I fitted my king carbon one, think you'll find the king carbon one might also fit abs models
    R&G one
    King Carbon
  6. Ian E
    Ian E Active Member
    I had one on my 2013 ABS but removed it when I sold the bike. I am going to advertise it on here £60 delivered so let me know if interested. I think they are about £115 new. There are some light surface scratches with use. As mentioned above, they are very solid but do take some lining up. I don't have the instructions (not that you need them!) and the I sourced the bolts as when I bought it I didn't get the bolts.
    Cheers,
    Ian.
  7. stu2907
    stu2907 Active Member
    Ian... I'll PM you
