2012 rear brake disc recommendations
Discussion in 'General 1000RR Discussion' started by keithg1748, Jun 7, 2015.
  1. keithg1748
    keithg1748 Active Member
    hi all just wondering if to stick with oem or any other makes , brake over heated and locked rear wheel on and its warp the disc. thanks
  2. foenix
    foenix Active Member
    BRAKETECH axis iron mate for performance or just Galfer for style and weight
  3. Slick
    Slick Elite Member
    think the Braketech also come in fully floated too so should reduce the likelihood of warping in the future.
    If you havent already do check the caliper, the piston may be sticking
  4. keithg1748
    will do mate thanks.
  5. keithg1748
    anybody used brembo series oro rear disc ? if you have any info would be good , thanks
