2012 rear shock stock settings
Discussion in 'Mods, Upgrades, Accessories and Products' started by RedMacGregor, May 5, 2012.
  1. RedMacGregor
    RedMacGregor Active Member
    Just fitted my recently aquired shock today but I've got no idea if the settins are stock or not. I would be grateful if one of the new owners of a 2012 blade could have a look in the handbook and post what the settings are.
    Thanks - Steve
  2. barry107
    barry107 Active Member
    Steve,
    2012 CBR1000RR Suspension Settings:
    (From full stiff)
    Fork
    Preload:
    Compression:
    Rebound:
    Shock
    Preload:
    Compression:
    Rebound:
    Edited as you beat me for the 2012 shock on evil bay :p
    #2 barry107, May 5, 2012
  3. Jamiestrada
    Ohhhh thats just nasty lol
  4. barry107
    #4 barry107, May 6, 2012
  5. Jamiestrada
  6. 1000rr73
    1000rr73 Active Member
    Manual says....
    preload
    1-3 soft / standard 4 / 5-10 hard
    rebound
    standard is counterclockwise 2.5 turns from maximum
    compression
    standard is counterclockwise 2.75 from maximum
    cheers
  7. RedMacGregor
    Thanks for the settings guys - sorry about the aution Barry .
    Just for anyone thinking about fitting one of these shocks I can tell you the Honda Racing rear hugger does not fit. I know someone on the forum said it just touched but mine was pushing down on the hugger while the shock was unloaded. When the shock compresses it moves downwards and would probably cracked the hugger. However, I'm thinking of getting the dremil on it to make it fit as the rear looks really bare now.
    Thanks again guys - Steve
  8. barry107
    No worries Steve, the man with the deepest pockets won!!!! ;)
    I've got one on it's way now :D
  9. pctriple
    pctriple Active Member
    Thanks. Was looking for the same info. Many thanks again. Are they the same for abs and non abs bikes?
    #9 pctriple, Sep 17, 2012
  10. RedMacGregor
    I can't see why they should be any different. The shock is excellent by the way - I've tried changing the settings but found the stock setting was about right for my weight. The only thing it does make you want to do something with the front suspension.
    Steve
  11. pctriple
    Just curious as they are slightly different for and without abs. Havnt booked it in yet , but FTR in bury will re valve spring and refresh the fronts for about £530. Hopefully in the spring time.
    Cheers.
