2012 track fairings to 08 bike.
Discussion in 'General 1000RR Discussion' started by Lifeofriley, Jun 7, 2018.
  1. Lifeofriley
    Lifeofriley New Member
    Hi guys as above im planning to get some 2012 plus track fairings to fit to my 08 blade. Have many people done this? Is there much differences other than nose can shape?
  2. si1000repsol
    Yes no issues with the 2012 track fairings on an 08 just ensure ensure you get everything 2012 including race air ducts
  3. Lifeofriley
    Thanks mate thats ideal.
  4. Lifeofriley
    Just to confirm will the 2012 upwards fairings line up correctly or will i need to make brackets for fixings?
  5. si1000repsol
    Yes will line up fine. Not quite the same but mine is an 09 with 2015 fairings so even stock fairings can be done too.
  6. si1000repsol
    Don't forget that you will need the race fairing fittings to bolt on the bike. These are the same 08-16 mate
  7. Lifeofriley
    Any idea where i get them from pal. Sorry for questions, blade is new tome. J
  8. si1000repsol
  9. Lifeofriley
    Cheers mate. Not like my old daytona then as they just fit straight on, sorry tobe a pain but what exact fixings do i need, just side fairing as front cone will mount on race bracket.
  10. si1000repsol
    You need Middle and lower brackets mate. Also something for the clock brackets (bolts if using stock) or dzus or m6 screws for race clock brackets
