2013 Blade indicators u/s
Discussion in 'Maintenance' started by paulbusdriver, Oct 26, 2014.
  1. paulbusdriver
    paulbusdriver Active Member
    Took bike out today whilst dry and sunny, indicators don't work. They have been removed for track days, sprints several times, but we're working when refitted last month. I've checked fuses under seat 10amp, which horn runs off(horn still works). Any ideas....if not still under warranty ,hazards u/s too. Cheers
  2. Pitcrew1
    Pitcrew1 New Member
    Check your indicator relay in the front cockpit behind clocks and connectors. The relays rarely fail, so I would suspect a poor connection.
  3. martinowen
    I had a load of dirt inside my switch, my bikes a lot older but may be worth a go
  4. paulbusdriver
    Update
    Seems I checked the wrong fuse, schoolboy error!! dived straight for the one marked "blinker/horn" didn't see the one marked "turn" which was the one blown.....all fine
