2014 Repsol screen question?
Discussion in 'Mods, Upgrades, Accessories and Products' started by R.M, Feb 4, 2021.
  1. R.M
    R.M Member
    Hey there....need to pick your brains. I'm going to change the screen on my bike as the current one has a few marks & scuffs/hazing. As it contains part of the "Repso" logo, it's not going to be a cheap fix. I have the part# for the screen sticker 86641-MGP-M31ZA (costing me €35 delivered to Ireland.
    Next question is....what's the best aftermarket option that will suit the OEM sticker?
    Should I stick with a replacement OEM screen? If so, what's the part#, as I can't find it anywhere.
    If I go down the aftermarket route, what's the best one to go for from your experience?
    TIA
    R.M
  2. CharlieR85
    CharlieR85 Elite Member
    I changed to the Zero Gravity Corsa screen and bought the same OEM decal you've posted above. The screen is excellent, takes a lot of the wind off you which makes it a lot more comfortable to ride. People tend to either go for Zero Gravity or MRA.
    The OEM decal does go on the taller screens but it's not 100% perfect, it leaves tiny gaps down the edges because it needs to be a bit wider to accommodate the taller screen. I'd say its good enough for 95% of people though. What I did was cut out the same shape as the decal onto 3m carbon vinyl making it a tiny bit wider. Then I stuck it to the inside of the screen directly behind the decal so when you're looking from the front the gaps down the sides are now black which stops them standing out as much.
    Honda actually sell a genuine taller screen which makes me wonder if they ever did a slightly wider decal to suit. Here is a picture of mine...
  3. Sam.moz86
    Sam.moz86 Active Member
    You could take the screen to a car detailers and have all the swirls / hazes polished out?
  4. R.M
    R.M Member
    Thanks for above advice lads.
