2015 decat
Discussion in 'Mods, Upgrades, Accessories and Products' started by leigh, Sep 7, 2019.
  1. leigh
    leigh Active Member
    2015 how do i decat my blade i have an akroprovic gp titanium pipe thanks in advance
  2. Stuish
    Stuish Senior Member
    The cat is in the headers on the 15, so a new set of headers would be the easiest way
  3. jonty
    jonty Active Member
    55mm core drill did mine just fine
  4. Alan Summers
    Alan Summers Active Member
    What do you mean???
  5. jonty
    jonty Active Member
    I've got a core drill I use for making 55mm holes through brickwork,works a treat for drilling out the cat in the headers
  6. Alan Summers
    Still don't understand what you've done tbh. Do you take the headers off and drill in them?
  7. jonty
    jonty Active Member
    No Alan,take off the end can from the headers,look inside and you'll see the cat,I used a 55mm core drill to remove the centre then chip off the rest of the material belonging to the cat
    Hope this helps pal
  8. Alan Summers
    Is this difficult and would it throw up any warning lights?
  9. Alan Summers
    Also, would I then need a PC5 or ecu flash?
  10. raphael
    raphael Elite Member
    Just cut the whole cat off and weld a piece of pipe in,
  11. Alan Summers
    Would I need to adjust fuelling sfter that?
  12. raphael
    Preferably yes, doesn’t matter what way you go about it, you’ll have to map it to get the optimum fuelling
  13. Alan Summers
    Thanks
