2015 Fireblade 3rd gear issue
Discussion in 'General 1000RR Discussion' started by Bakweel, Jan 26, 2021.
  1. Bakweel
    Bakweel New Member
    Need advice fellas. 2015 Fireblade trackbike. Did a track day today and finished up with a rattling/noisy 3rd gear. All other gears are still quiet in drive/incl on the stand. It hit false neutral twice mid corner before the noise was really obvious. This gearbox has hit false neutral many times on the track in several gears though. It doesn't feel as solid as my 07 Blade. I have an aftermarket quickshifter and admittedly wasn't firm enough on it changing gears until I got used to that pressure so that may have started another problem. Maybe I've damaged a tooth as it feels like it's skipping a tooth or the selector is perhaps not engaging third gear effectively. Anyone had this issue or have some suggestions? Cheers
  2. Boothman
    Boothman Elite Member
    Hi and welcome to the forum. I’m no tech wiz but third gear is a well documented Achilles heal on track from what I’ve read. There are beefed up alternatives that sound to resolve the issue. No doubt someone with more info will be along to advise.
  3. Frazzle
    Frazzle Active Member
  4. Bakweel
    Bakweel New Member
    T
    Thanks for the info and link guys. Our guys mentioned here in Oz about Nova's gear so looks like the goods apart from a full HRC gearing rebuild.
  5. NS400R
    NS400R Elite Member
    I used Nova for gears on my NS400 at rebuild time. The quality is superb. Jewel like
  6. CharlieR85
    CharlieR85 Elite Member
    Didn't realise the weak 3rd gear issue ran all the way to 2015 :eek:
  7. LowSide76
    LowSide76 Active Member
    Neither did I thought 2015s were solid bikes
  8. Bakweel
    Bakweel New Member
    Guess not. Pretty annoyed about it actually.
  9. Jimmy Hope
    Jimmy Hope New Member
    Had the 2010 and 2012 used for track use and 3rd gears were weak, its a known fault you could get the gears polished hardened think they call it , ,
  10. Bakweel
    Bakweel New Member
    With this paper thin looking gear I'm surprised it lasted 8500km.
    The price we pay for weight reduction.
  11. NS400R
    NS400R Elite Member
    That's bad! I would have thought it would be a dog that goes, not the teeth :eek:. What causes the teeth to go I wonder?
  12. Bakweel
    Bakweel New Member
    Must be the paper thin skin they are cast on.
  13. tuktuk
    tuktuk Elite Member
    Alot of power being banged through a very small area. You would think it would take less than 8 years to sort the problem though.
  14. Bakweel
    Bakweel New Member
    Absolutely, I'm happy to gain 200gm weight for the sake of not pulling an engine out. My 07 Blade was track flogged forvl 10000km and never had an issue, engine or box.
  15. Bakweel
    Bakweel New Member
    Looks like Honda casting is as weak as its gearing. Under big end caps.
