2015 . indicators and hazards stopped
Discussion in 'General 1000RR Discussion' started by sunnybryn69, Jun 12, 2022.
  1. sunnybryn69
    sunnybryn69 New Member
    Hi. My hazards and indicators not working. Checked the 10amp fuse it's good . Any help will be welcome
  2. Muffking
    Let me know your email address and I'll try to send you the diagram (12Mb).
    In the mean time I'd check for 12v at the relay when the indicator/hazard is in the ON position.
  3. sunnybryn69
    [email protected] cheers .where's the relay location
  4. Muffking
    Sent.
    I don't know the locations, but it could be under the main seat, or like on the older one behind an upper side fairing.
  5. sunnybryn69
    This is the relay . My problems
  6. CharlieR85
    CharlieR85 Elite Member
    It's a pain to get to. It's behind the dash. You need to get the nose cowl moving to get at it.
  7. sunnybryn69
    Yeah nightmare also my blade is a former undercover surveillance bike so wires going to places where thing be before
  8. CharlieR85
    That could really complicate things. Good luck.
  9. Stuart Gould
    Stuart Gould Active Member
    Does it have an alarm? I changed the indicators to some cheap ones before and it popped an inline 10a fuse for the alarm. One from the positive battery terminal. Put new one in and all worked again. Never fitted cheap ones again. Other than that, you have a fuse under the seat for indicators and a relay behind the front nose fairing. Could be either.
