2015 SP runing rough below 6k RPM ( helpeith codes)
Discussion in 'Maintenance' started by kevin nichol, Oct 21, 2018.
  1. kevin nichol
    kevin nichol Active Member
    Just converting a 2015 SP into a track bike. Took of Pair solinods and fitted plates removed side stand , airintake sensors and oxygen sensor ( replaced with bypass plug).
    Now the bike is ticking over nicely but once you rev it it's missing badly untill it reaches 6k RRP. Then spits back blue flashes no and then.
    Fitted new Translogic quick shifter and full Akrapovich system. Any advice on what it could be?
    The code that is coming up is 3 long blinks Then 4 short blinks.
    Cheers
  2. Barstewardsquad
    Think 34 is the exhaust servo, or it was on the rr7. If so you can try rotating back to clear the error, or alternatively fit a servo eliminator and then ditch the servo completely.
  3. kevin nichol
    Just realised I have taken the exhaust servo off and not fitted an eliminate. Hopefully this will cure the problem Ian having. Cheers
