2016 standard exhaust servo valve reinstall help
Discussion in 'General 1000RR Discussion' started by Glenandemm, Oct 29, 2021.
  1. Glenandemm
    Glenandemm Active Member
    Hi lads a mates asked me to put his standard can back on tomorrow, got no problem with installing it all apart from the cables and connecting them back up to the servo, is there a certain position I need to set the motor too to install the cables as I don’t want to set any lights off on the dash!
  2. Fatboy
    Fatboy Active Member
    Is it the EGCV or the EGCA your looking for? . Have put up the later type
    or
    #2 Fatboy, Oct 30, 2021
  3. Glenandemm
    Cheers buddy seen this message late but got it sorted first thing this morning!
  4. kirk holmes
    kirk holmes Member
    I brought my bike with a racefit fitted but was thinking of reinstalling the standard exhaust for a track day. Fitting the exhaust looks simple enough its just the cable to the exhaust servo that Im not sure of. Any suggestions or tips?
    Did you get another bike Glen?
  5. Boothman
    Boothman Elite Member
    It’s not a necessity to refit the servo cables if you put the standard can back on. I have the standard silencer, but disconnected the cables, removed the servo and fitted a servo eliminator to stop any error messages. Only did it to get away from the annoying sound change generated by the valve opening and closing at whatever revs/speed it was.
  6. kirk holmes
    kirk holmes Member
    Thats helpfull Boothman, so if i dont refit the cable the bike will run just fine but i may get an error message? I need to look to see if a servo eliminator was fitted by the previous owner.
  7. Boothman
    If you aren’t getting an error currently I’d expect there is an eliminator fitted, or if the servo is still installed someone has done something to it to stop it from keep on turning.
  8. Plodder
    Plodder New Member
    Sorry about posting on this oldish post, I have an 2018 CBR100rr sp, replaced the standard exhaust with a Yoshimura slip on, left the servo motor in place without the cables attached to it, no error codes at all, bike runs perfect no dash lights, run the bike for past 12 months like this, can anyone explain why they are paying money for a "servo eliminator", have I missed something here, is there any benefits to be gained?
    I would appreciate your comments.
    Steve
  9. Coda
    Coda Active Member
    Yeah you can remove the servo mechanism to save weight. Not a biggie in many cases but could be useful if stripping out a lot of the other useless stuff
  10. Plodder
    Plodder New Member
    Thanks Coda
  11. karl wesley
    karl wesley Active Member
    done my 19 plate exhaust removal nearly 12 months ago,left the servo in place with just the cables disconnected,no issues at all.Today coming back from a run light came on dash and dtc code 35,EGCV error.bike bogged down in limp mode.
    servo eliminator ordered .Tomorrow will be stripping the servo off the bike.
  12. Plodder
    Plodder New Member
    Hi Karl, have you removed the cables completely? Mines covered 7,000 miles with the slip on exhaust, no servo eliminator, no lights on, yet.
  13. karl wesley
    hi mate,
    no cables were just disconnected, will remove today.
  14. Plodder
    Plodder New Member
    Hi, Cables might have moved or hitting something when activated by the servo. Remove them, keep the servo connected, not sure if you will need a reset to turn the light off, please let me know how you get on.
  15. karl wesley
    well servo came off easy enough and servo eliminator fitted,put it all back and light was still present.tried the jumper trick in the dtc cable and now got this WhatsApp Image 2022-08-24 at 12.27.20.jpeg
  16. Plodder
    Plodder New Member
    Have you knocked the fuses or the battery cables, may be when you used the jump wire, for the reset, you have shorted something else and blown the fuse, give them a check. Try putting the servo back on.
  17. karl wesley
    yeah popped a fuse,changed it, all came back on,still got the check engine light,dtc now showing code 34,previous 35,server eliminator from healtech,
  18. karl wesley
    well the plot thickens :mad: turns out i have a broken wire to the clip that the servo plugs into.a WhatsApp Image 2022-08-24 at 16.31.23.jpeg WhatsApp Image 2022-08-24 at 16.31.41.jpeg
  19. karl wesley
    any idea if the cable can be re-inserted ,do they push in ?
  20. Coda
    Coda Active Member
    That needs a length of wire soldering in.
