2017 cbr1000 rr Honda quickshifter problem
Discussion in 'Maintenance' started by Stewart Lacey, Feb 6, 2019.
  1. Stewart Lacey
    Stewart Lacey Active Member
    hi all
    Fitted a new oem shifter and it’s very stiff to change gear. It’s l8ke it’s not working. Everything is switch on. Am I missing something
  2. Selmer50mark
    Selmer50mark God Like
    Hello and welcome Stewart, I can't help you but hold on in there ,someone will
  3. nigelrb
    Hi Stewart and welcome.
    I have the QS factory fitted on my 2018 so I can't offer much in the way of a fix.
    However, I do suspect it is related to the 'sensitivity level' required to change gear. On the factory jobs, we have a 'sensitivity' setting within our dash controls. That will adjust the pressure required on the lever to change gear. (Page 54 of 2107-18 Owner's Manual)
    I do not know if the later fitting of the OEM shifter will plug into the electronics to allow you to adjust this via the dash/ECU. There might well be some mention of it in the instructions that accompanied your purchase. Otherwise, it might mean a red-faced trip to your dealer.:(
