Hi all, I am actually looking at some lightech rearset next but it need a brake banjo switch installed which will need a rear brake bleed at the worse case. Just wondering if anyone here got any info on brake bleed on 2017 ABS system, I have seen the microfiche and looked like its resemmble the simpler ABS system, so anyone know the procedure if I need to bleed them? I'm also looking at putting a Brembo MS on the front as well so it could be useful. Thanks
Mine is a 2013 I fitted brake lines all round, I thought give it a go at standardish bleeding,I reversed filled the lines with a sringe All worked OK for me, I did run quite a bit of fluid through but bought a big container. I was expecting major problems and having to take to a local stealer,
