2017 RR heated grips, parts number?
Discussion in 'Mods, Upgrades, Accessories and Products' started by Omer, Nov 18, 2020.
  1. Omer
    Omer Active Member
    Are the heated grips same through out the years, or do they all have different part numbers. Looking for a 2017 RR.
  2. stelwalker
    stelwalker Active Member
    Can't go wrong with the Oxford sports grips, just fitted a set of advanced ones...
  3. Omer
    Omer Active Member
    All the aftermarket ones put me off just based on the control attachment.
  4. stelwalker
    I know what you mean ended up sticking the controller just under the screen, don't think it looks too bad but this may effect others OCD. Must admit mind do knock the hazards on occasionally if using on the move :confused:
  5. Saqib
    Saqib Active Member
  6. stelwalker
    As long as they suit the bar diameter suppose anything will go on. Took me 3 goes to get mine to stick super glue did the trick in the end
  7. bladerunner03
    bladerunner03 Active Member
    Check out Andymancam fitting the Daytonas here
  8. Omer
    Omer Active Member
  9. Omer
    Omer Active Member
    I beep people all the time as it is....
