2018 SP sticking gear lever
Discussion in 'General 1000RR Discussion' started by Samtp, Aug 14, 2021.
  1. Samtp
    Samtp Active Member
    Hi everyone
    Has anyone experienced a sticking gear lever when downshifting?
    On a typical hour’s ride I’ll get this problem once or twice. What happens is that when I’m downshifting, the gear lever stays down for a moment and I can’t downshift again until the lever pops up - I feel it hit the bottom of my boot. Normally, it’s only for a second or so - but I’ve not experienced this before on a bike.
    Most times it’s when I’m changing from 3rd to 2nd.
    I’m using the autoblipper.
    I talked to the dealer about this and they said to be more positive with my gear changes.
    Any thoughts appreciated.
  2. Jez
    Jez Senior Member
    Hi, I am no expert but had the false neutrels issues from a 2013 bike, If it is a low mileage bike may need a few miles to run in
  3. NS400R
    NS400R Elite Member
    What the dealer said. If you're certain you're being positive, then you might have a problem, but I'd check you are first.
  4. Samtp
    Samtp Active Member
    Thanks for the replies - I’ll also try adjusting the gear lever as it’s a little high.
  5. stuart_g
    stuart_g Active Member
    I get the same thing but on up shifts. Usually when the engine is under more load. Never get a false neutral just feel the lever hit the top of my boot.
  6. Samtp
    Samtp Active Member
    How often does this this happen for you? And has it worsened or got better over time?
  7. bonjo
    bonjo Active Member
    I have found new boots make a difference depending on the sole thickness & stiffness and it takes time get get the feel of the gear lever after changing boots.
    Could be you are dragging your boot on the lever after a change so it does not come back up.
    Initially, Change down manually and slower, making a positive foot movement to leave a gap to the lever after each change. Maybe this recalibration will solve your prob
