2019 brake fluid change
Discussion in 'Maintenance' started by karl wesley, Jun 1, 2022.
  1. karl wesley
    karl wesley Active Member
    anything complicated ? or is it just bleed the two cylinders ? local guy suggested its got to go to a dealer.but im guessing he was confused with the previous multi point bleed fiasco ? any pointers ? tia
  2. Ian E
    Ian E Active Member
    2017 onwards bleed procedure is straight forward - conventional bleed.
    Cheers,
    Ian
  3. karl wesley
    thank you
  4. Saqib
    Saqib Active Member
    I did my 2017 blade, and its straight forward. Put rags everywhere to catch any stray drops of brake fluid.
    I got a good tip: use a tie wrap to hold the brake lever closed overnight. It allows any trapped bubbles to come up with teh system under pressure. Makes no sense.. but it worked on mine!!
    I found the rear brake fluid was much worse that the front!
  5. karl wesley
    thanks matey
